Gearbox and overdrive out - now what?
Posted by gregwni
gregwni Avatar
Greg W
Belfast, Northern Ireland, United Kingdom   gbr
IVe got the gearbox and o/d out of the car now (its an early rb blue lable od). I dont know if the overdrive works or not as i never had it in use (i bought the car and pretty much took it apart - ive never had it on the road!).
What, in this state, can i check and how?
(I dont want to have to put it back in the car to find out it has problems!)
thanks in advance...
P.S. (Im going to change the gaskets, oil seals and clutch - inc roller bearing).
twigworker Avatar
Jack Austin
Blowing Rock, NC, USA   usa
Wow! That's a genuine and certified used up release bearing!
You could rig up a test bench but I don't know that doing so would tell you much about the effectiveness of the pressures or the condition of the cone clutch. If I were you I would just replace the rear seal, along with the transmission front seal and gasket, and clean the strainer. You might reset the pump ball too, and hope for the best. Oh, take a few minutes and test the reverse lamp switch and the one for the OD lockout.
Jack
---------------------------------------------------- Services to Interesting British Automobiles-- www.jackscars.net ----------------------------------------------------------------
Jacks Cars - Services To Interesting British Automobiles Over 40 years of caring and capable services to British cars and their owners. For help or advice please call 828-295-0224, email to jackscars@charter.net or go to www.jackscars.net.
gregwni Avatar
Greg W
Thanks Jack - yeah - that bearing is so bad i thought part of it must have fallen out (before i checked to see what they are like!). I havent had the gearbox or od apart yet, so im a bit lost on what id have to do with :
"You might reset the pump ball too, and hope for the best. Oh, take a few minutes and test the reverse lamp switch and the one for the OD lockout. "
I can probably figure out the reverse lamp one, but not sure about the pump ball and od lockout?
sweep Avatar
Chris W
Gosford NSW, Australia   aus
1966 MG MGB "Basil"
1990 Nissan Patrol "(Patrol) The Beast"
1992 Subaru Legacy "(Liberty)"
Greg, you may get some benefit from looking at the last half dozen or so entries of my journal. Same journey - older animal, but.....
Chris, and I love my overdrive!
Jim and Kathy Buckalew
Kingsville, Texas, USA   usa
1978 MG MGB "Barbie"
1980 MG MGB Limited Edition (LE) "Elvira"
I would pop the side cover and take a close look at the internals. Look for metal flakes and general condition. You cant look inside the OD unit but if anything is going on with it, any damage will show up in the main gear section.
gooser Avatar
Drake Myers
Danville Va, USA   usa
with the bottom cover removed you can turn the output shaft and tell whether the pump is working or not. the od lockout looks just like the reverse backup light switch.
