sebring style fender flares
domer94 steve bendo
springfield, USA   USA
was wondering where folks have sourced these and how difficult they are to install. also , with the added clearance, what type of offset on the wheels are used to fill the space nicely? the B i have purchased is a good candidate for this look.
thanks!
1974 MGB - magenta -- custom
1989 Saab 900 turbo vert - red / tan int
2005 Jaguar S-TYPE racing green
2004 mazda6 wagon - family truckster (cool)
dtownsend Avatar
dtownsend Gold Member David Townsend
Rutland, Vermont, USA   USA
1978 MG MGB V8 Conversion "B'east"
Dave Craddock @ Preform would be my one and only choice for Sebring wings and body kits. I had a set of the flares commonly sold through the MG aftermarket and will tell you there is simply no comparison to the Preform product. Dave's parts fit correctly (something I can't say for the other kit), look great, and are well made as well as competitively priced. Not much more I can add.
Limited edition fine art prints of British sports and racing cars
Simon Austin Avatar
I used the flare kit available from the MGOC in the UK. The grey car in my profile has them installed.
I don't have the expertise required to make these work but my body man does. It was a major project to get them to fit properly and look right.
They've been on the car for about 8 years now and holding up well.
I've mentioned before on here that I'd suggest anyone contemplating this conversion not to use the complete front fender. Remove the flare and attach that to your steel fender. The rears are better as all you get are quarter panels.
It's a big project but worth it in the end.
We sell the guys with Sebring and similar flares the 15x7 0 offset wheels we have them in all the VTO styles, Classic 8, Retro $ and Lemans, we also got some 16" we can use on the MGB with flares fenders as well in Classic 8 silver. The 0 offset work real well, be cause it move the wheel outboard 2" when compared to the popular stock fender MGB application, 15x6 +24mm, The 15x7 O offset works perfect with the flares car, you get extra width and less back spacing to space out to the flares,and you can get some pretty sporty rubber with the size wheel. Alot of the 15x7 on the market will have alot of positieve offset with FWD cars in minds, these wheels wheels were designed for RWD applications.
Edited 1 time(s). Last edit at 2012-05-17 11:24 AM by Speedracer.
dtownsend Avatar
In reply to # 2070050 by Simon Austin I don't have the expertise required to make these work but my body man does. It was a major project to get them to fit properly and look right.
With respect to Simon, I had the same MGOC body kit and I agree with his assessment of the fit. Instead of taking the body shop route, I sold the MGOC kit and went with Dave Craddock's parts (as stated previously). Both the fronts and rears fit properly. In fact. The fronts bolted right up and, other than some expected cosmetic bodywork, nothing further was required. If these were going on a race car, there were good enough out of the box that I don't think I would even bothered with fixing a few of the minor blems.
domer94 steve bendo
this is what i had in mind...
PaulSchils-AC.jpg    69.5 KB
Be Coming Avatar
Be Coming Kelvin Dodd
So. Calif., USA   USA
Steve.
For that amount of flare, either go with cut off Dodge Omni sheet metal welded to the original steel fenders or check out the Huffaker fender flares which bond to the original panels.
The Sebring kits and Preform kits are a lot more aggressive.
You would be looking at around a 215 series tire to fill the fender as shown in the image above. A 15 x 7 wheel with about 15mm offset would work well.
Simon Austin Avatar
I agree with Kelvin. Those aren't Sebring flares. Not big enough. They look good.
This is my car with the Sebring flares.
2008 ABFM 003.jpg    82.4 KB
2008 ABFM 001.jpg    71.8 KB
David, when can see more of your car in pics, like a closer look at your splitter front air dam, it looks preety darn cool, and well executed.
Be Coming Avatar
So. Calif., USA   USA
Nice Simon.
I don't think I've seen your car before.
I'm stuck with the Honeybourne Sebring flares, because I want the same character line on the rear fenders that your images show really well.
Kelvin.
kerbau53 Avatar
kerbau53 Gold Member Geoff Morton
Cape Coral, Florida, USA   USA
In reply to a post by Steve this is what I had in mind...
I think the Huffaker style flares are very good looking on a roadster. I'd like to see how they look on a GT too.
dtownsend Avatar
In reply to # 2070364 by Speedracer David, when can see more of your car in pics, like a closer look at your splitter front air dam, it looks preety darn cool, and well executed.
Here you go. The valance started off as a typical Sebring style valance which I sectioned and 9" in the middle (so it would match the width of the preform wings), then filled in all of the stock openings, re-glassed everything, then cut new openings as close as I could get to what the original LeMans cars had. The "horns" for the brake openings were bent from flat stock then riveted on (similar to the originals). The ducts on this car feed cooling for the front brakes. The oil cooler frame was another part I noticed in shots of the early race cars and is also riveted on as per original.
The splitter profile is about the same as the curve of the front end and does not extend any farther than the front of the bonnet. It's attached to a set of brackets that bolt to the frame rails. Once I put the quick release pins in the front adjusters, it will be about a 5-minute affair to remove it if I ever want to trailer the car. The splitter tin work was made from flat stock and pounded out on a shot bag and a bench vise. The tin work does a very nice job of stiffening up the corners.
I also included a shot of the car from a few months ago before it was all in primer.
Edited 1 time(s). Last edit at 2012-05-17 07:27 PM by dtownsend.
splitter_front.jpg    40.4 KB
splitter_3_4_finished.jpg    39.5 KB
MGB_front_low.jpg    22.8 KB
MGB_almost_ready.jpg    35.7 KB
Sly52005 Mike Wickham
Canmore, AB, Canada   CAN
Steve,
Let me know what you find out on these minor flares. I really like the look...where did the picture come from?
Mike
kerbau53 Avatar
Simon Austin Avatar
Thanks Kelvin. I don't post many photos of it so doesn't get a lot of exposure.
I like the look of the body line through the rear flare as well. Gives it a finished look.
