just got a new mgb.......and now it's broken
Posted by joem
joseph mandra
la grange park, USA   usa
i just got a 77 mgb from a friend and up until now it has been running great. i dont really know much about cars so expect some of the terms to be off. it started with the car shutting down when i would come to a stop if i didnt rev the engine and now it wont even start up at all. the engine rev problem happened when i first got the car and my other friend who actually has a few mgs himself suggested i put new gas in it since it was sitting around for a year and it worked. i tried that again this time with no luck. i was told it was the starter by my friend said that my friend who sold the car to me already replaced the starter twice so he thinks it has to be something else besides just that. i made a video of me trying to start up the car because there is no way i'd be able to explain everything in words. the key doesnt actually start the car, instead the car is started by pushing a button on the panel
here's the video:
if anyone knows what it is or has any ideas on how i can fix it that would be great, its finally getting warm and i'd really like to drive my car
rntanner Avatar
Roger N. Tanner
Ventura, CA, USA   usa
1970 MG MGB
Remove the starter and see if the teeth on the flywheel are missing, or the teeth on the end of the starter are missing.
joseph mandra
In reply to # 2038394 by rntanner Remove the starter and see if the teeth on the flywheel are missing, or the teeth on the end of the starter are missing.
this is gonna sound dumb.....but how hard is it to remove the starter, should i just have my friend do it?
and whats a fair price to pay if i need to buy a new one?
curtis7420 Avatar
Curtis Wright
Univerisity City, MO, USA   usa
you definitely need to talk to whoever it was that installed all those switches and push button starter. i have no idea, and i doubt many other will either, what all you have done, have to do, to start this car. i've seen push button starters before, but all you usually have to do is turn the key and push the button.
you could trace all the wires. or, you could by-pass things and attempt to start the car from the engine bay - ie. removing a wire from the starter relay and touching it to a fuse.
someone with more experience than me will surely chime in and tell you exactly what to do. but i would start by finding out exactly what the switches are for...
good luck
curtis7420 Avatar
Curtis Wright
In reply to # 2038398 by joem
with that sound, it could be the teeth.
it's not that difficult to remove the starter...
you can get a good used starter for as little as $50. have it tested at autozone/advance auto for free before putting it in the car. the first one i bought was bad and i took it back to the person i bought it from and they just handed me another used one that i've had no trouble with so far.
joseph mandra
but would the starter also be the reason why the car was shutting off when i wasnt revving the engine?
Youngmgbuilder Avatar
Olin Reed
Hyde Park, Vermont, USA   usa
1972 MG MGB "Jenna"
In reply to # 2038404 by joem but would the starter also be the reason why the car was shutting off when i wasnt revving the engine?
If your stopped you have to have your foot on the clutch. The starter basically does nothing but start the car, so that isn't the problem
ozieagle Avatar
Herb Adler
Geelong Victoria, Australia   aus
1958 Wolseley 1500 "Wooly"
1966 MG MGB "Bl**dy B"
Check the cables from the battery. Corrosion on the terminals, just loose, bad connection the the body, faulty cable.
Herb
Delbert Golightly
Spanaway Wash, USA   usa
Joe........sometimes the gears on the flywheel gitt worn, so the stater motor Bendix never meshes. Interestingly enuff, 4-cyl engines almost always stop at the same place, so guess what? BAD flywheel gears again. Eazy'nuff to check, putt'chur tranny in 3rd-gear and PUSH car a couple of feet .....then try to starter. Simple, eh? Iff'n it starts right-up, guess what? Yer flywheel ring gear is worn and ONLY cure is pulling the engine and replacing flywheel. Me? I can push a car alotta times before I pull an engine.
As fer yer dashboard push-button starter scheme. Previous Owner didn't know that the steering column switch is replaceable so he cobbled a simple push-button replacement. My '76 PO did that. I just haven't gotten around to re-keying it. It kinda depends upon how tight yer sphincter is. ........Dell who doesn't care about "originality"
arkay Avatar
Ronn Kilby
El Cajon CA, USA   usa
1979 MG MGB "Sabrina"
2004 Harley-Davidson Dyna
The good news - you got an MG! The bad news - yep.
I think you should sell it and buy a Miata. That rocker switch thing is SO "DPO" that I hate to think what lurks elsewhere. Even if you do get her going, it's probably just the beginning. A 35 year-old poorly-maintained car is not the best choice for "un-mechanical" folks who just want to get in and drive "because it's finally getting warm." Just my gut reaction. Good luck my friend.
joseph mandra
what's dpo?
and part of the reason i bought the car was because i figured there would be problems and it would force me to learn how to fix a car
PaulM Avatar
Paul McLaren
Lower Mainland BC, Canada   can
1968 MG MGB
1969 MG MGC GT "Willow"
1970 MG MGB "Miss Lou"
1970 MG MGB "Dolly"
In reply to # 2038406 by Youngmgbuilder
Sitting stopped with your foot on the clutch will wear out the carbon throw out bearing.
Paul McLaren
1969 MGC GT
1970 MGB Roadster
1970 MGB Roadster
arkay Avatar
Ronn Kilby
DPO is "D..." Previous Owner. If you want a course in auto repair, you bought the right car. Just be ready for a LOT of learning. Best - and enjoy the ride. I hope this is not your only vehicle.
joseph mandra
In reply to # 2038497 by arkay DPO is "D..." Previous Owner. If you want a course in auto repair, you bought the right car. Just be ready for a LOT of learning. Best - and enjoy the ride. I hope this is not your only vehicle.
no i've got a daily driver thankfully, i only paid 800 for it, my friend said it wasnt that great of a deal, but for me 800 to mess around with a car and maybe drive it every now and then isnt that bad
arkay Avatar
Ronn Kilby
Kewl. I'd suggest 3 things. First take a class at your local community college in basic auto repair. You'll enjoy it -especially if they let you bring your car in. Get some tools (sockets, wrenches, etc) and plan on a few "MG specific" tools as well. Get a copy of the "Bentley" repair manual (best price is on Amazon). It's not cheap but you'll need it - and it's got something in there about everything you need to know. And of course there'e a wealth of info here at the forum - use the search before you ask, chances are someone has already covered your question. Good luck - and keep us posted on your progress.
curtis7420 Avatar
Curtis Wright
don't let these people discourage you. no one has seen your car in person, so no one knows how bad it may or may not be. it could possibly be an easy fix, but...maybe not. yes, these cars can be a heap of work. but you will also hear stories of those who don't have problems for years and years. it all depends on how well it was maintained. but i would have to agree, when you see something like your starter set-up, it usually means there have been shortcuts taken all around the car. hopefully for your sake, there's not.
more will chime in on a fix for your starter. if not, simply use the "search" in the upper right of the screen. just put in something like "starter problems" and see all that comes up. definitely pick up a shop manual - preferably the Bentley for your year. but here is an electronic version of it for earlier year cars but it can sometimes be helpful:
http://www.bmcno.org/manuals/MGB%20Workshop%20Manual.pdf
personally, i have one by "Clymer" that came with the car and i'm pretty happy with it.
also, use the "library", found on the left side of the screen (and now also left/center in the upper part of the screen). invaluable info there too.
whatever your problem(s), people/info on this site will walk you through it - give it some more time for others to respond. but please don't get discouraged by some of the comments you've received. about the worst possible thing that i would have to agree with someone telling you to start over with anther car is RUST issues - unless you have some welding skills and don't care to drive your car for a while. the cars are a blast to drive AND to work on. i'm still very much learning myself, and LOVING EVERY MINUTE OF IT!
again, good luck and DO NOT GIVE UP! oh, and post some pics of your car.
78mgb Avatar
White Wonder 78mgb
apple valley, Minnesota, USA   usa
1978 MG MGB
Since the car has been sitting for a long time, check the gas filter. It probably needs replacing and it is easy to do. Any car sitting for a long time is prone to having rust in the gas tank that can keep it from running.
By the way a great resource about car repair and maintenance is here: http://www.mgexperience.net/library/
Good luck. This is a great place to ask questions when you become stuck.
1977mg-mgb Avatar
Maxx M
City, USA   usa
1977 MG MGB "Little Green Sprout"
your starter isent engaging properally, it could be as simple as replacing the starter, or haveing to pull the motor and replace the fly-wheel. hey, atleast youll learn more about cars in the meantime. and as far ar the reving problem, you probally have to ajust the carb(S) if you have a stromburg carb or a weber, not that hard. but if you have dual SU's, it could be a bit of a task.
Edited 1 time(s). Last edit at 04/12/2012 06:49PM by 1977mg-mgb.
applebj8 Avatar
Jon Appleby
Lake Wylie, SC, USA   usa
Joseph,
If you get back to this thread, check out the Library link along the left margin. Your intuition is correct, you can learn a lot of basic car maintenance from owning one of these beauties!
Someone has really cobbled up your wiring harness - none of those switches should be necessary. Wiring diagrams are online at http://www.advanceautowire.com/ See, you now have an opportunity to learn how to interpret schematics!
There is a comprehensive list to get any neglected MGB running again:
http://web.archive.org/web/20070714104323/www.theautoist.com/awakening_a_sleeping_b.htm
And of course you have this site to help you along with whatever you encounter...
Good Luck
Travis K
Homestead, FL, USA   usa
JM,
This forum is an awesome resource and you can totally fix your car. We got our B about two months ago and i dont know much about cars at all. Researching the forum and library articles we made a huge improvement in performance for only about $200. An additional 10 mph at 3000rpm on the highway.
Good luck!!!! Sorry I don't know what's wrong with your car but I bet someone around here does. Just wanted to share some encouragement.
