high ratio rocker arms plain bushed...
Posted by dukeodray
david reynaud
fargo, nd, USA   usa
Hi,
Anyone know a source for 1.6: 1 rocker arms without the neddle rollers? I've read many places, including P.Burgess' book, that shaft rollers wear out fast, but that the high ratio rockers with plain shaft bushes hold up well.
Thanks,
Dave
the omega man Avatar
phil wilkins
staffordshire, United Kingdom   gbr
Hello David,I do not know a source for the arms.But I was interested to know what gains you would get with high ratio arms over a set of standard arms.
Steve64B Avatar
Steve Opitz
Phoenix, AZ, USA   usa
1966 MG MGB
David... who's rockers do you have?
First place I'd look would be the manufacturer.
I know in Phoenix there's a speciality shop that does noting but bearings... it might be a little tougher in Fargo, but Chicago must have something!
You could start by going to the Oilite site, or at McMaster/Carr which is a master distributor, but my guess is knowing a good machinist will be very helpful.
Edited 1 time(s). Last edit at 04/12/2012 05:45PM by Steve64B.
david reynaud
fargo, nd, USA   usa
Hi Phil,
I've read in Peter Burgess' book, How to Power Tune MGB 4 Cylinder Engines that the gain can be as high as 10%.
In his Power Recepies chapter, Burgess cites one car in particular, that had a 9 BHP gain, using high ratio rockers. They come in 2 types, a simpler, much less expensive,( several hundred dollars), configuration, that does strain the valve train components, because of the geometries that it posesses. The other much more costly type,($1200-$1700), that has far better geometries, which put much less strain on the valve train. This better type relocates the rocker shaft further away from the valve tip, about .070" and keeps the pushrod closer to the original more vertical angle; this puts less side load on the lifters and valve stems. On this better version, the contact half of the arm is longer, causing less wear on the stems.
So why spend so much on HRRs to get more lift, lift that can be achieved with a performance cam, that costs far less? The answer is, that a higher lift cam gives more lift, at the expense of increased duration, which is not always desirable in a street engine. More duration, along with high lift reduces cylinder pressure at lower rpm, where a street car tends to operate. With a higher lift cam, power increases occur mostly at higher rpms. HRRs increase lift without significantly increasing duration. This gives the engine higher torque, and more power througout the entire rpm range, not just the upper end.
I haven't purchased a HRR set, but just wondered if anyone knew of a source for bushed, not roller bearing HRRs.
Thanks for your interest Phil,
Dave
Adrian Page
Nova Scotia Canada, Canada   can
Harland Sharp make HHRs with plain bushings. I also found someone who offer modified stock rocker arms with offset bushings to increase the ratio. I'll see if I can find them again.
David Witham
Warwick, United Kingdom   gbr
If you use offset bushes in the rockers and bore the pedistals to take the same rotated 180 degrees you will maintain the push rod angle and hammer position over the stem.
I am not sure how easy it is to buy offset bushes though. You might have to get a machine shop to make them for you.
Greenville, SC, USA   usa
1967 MG MGB "The Biscuit"
On my MGB race engine I have Titan 1.625 roller rocker arms, Fred got them from Brown nad Gammon in the UK, $530 delivered to his door, a year ago, they are bushed on the shaft, and this drasticly reduce the cost of the Titan RR arms, Titan makes bushed version of their roller rocker arms for Mini Spares for the A series engine, and Brown and Gammon for the B series engine, a needle bearing on the shaft of the regular Titans, make the price alot higher as I mentioined, but there's no reall good real reason to have a needle bearing here to begin with. Now I will tell you this, we had to wait about 3 months to get the 1.625 ratio Titan set up from B&G, but it was worth the wait, it is a complete assembly even has lovely aluminum solid sapcer on it, and nice correct ratio pedestals, it been on the race engine for over a year now, and performing flawlessly.
BumbleB74 Avatar
William Milholen
Tidewater VA, USA   usa
Hap....any real benefit on a stock type street engine?
1976 Roadster, un-named, Sandglow - "driver" condition (stock + 32/36 Weber DGEV, cast iron header, 25D distributor), bolt on wheels
Winston Shift Right Avatar
David Crosby
Lone Tree, Colorado, USA   usa
1953 MG TD "Martha Ann"
Adrian Page
Hey... nice find. Any report on what difference they make?
David Crosby
In reply to # 2039019 by pinkyponk
Holy Crap! I step on the accelerator and I am slamed back in my seateye popping smiley
OK... Really I might be able to sense something weather it is just a placebo or not. It has to do something to give that engine some more HP like Peter sayssmiling bouncing smiley. It sure won't take HP away.
You have to ream the bushings or have them reamed once you press them in and then there is the discussion as to weather the oiling holes should be drilled or notconfused smiley.
And why did the engineers design a little resivoir in the original bushings? To keep a little oil in the bushing for start up before pressure builds upconfused smiley?
spikemichael Avatar
Michael Caputo
Athol, MA, USA   usa
1973 MG MGB "Freebie"
1976 MG MGB "B-4"
1979 MG MGB "MegaBeanie"
1989 Suzuki Intruder 800   → more
I would trade 10 HP for 10 lbs of torque any day.
Saw the offset Rocker Shaft Bushes, not exactly sure why they have to be offset like that rather than just thicker walled.
How I do you make them line up perfectly.
Interesting idea though.
How much lift do you gain?
Michael J. Caputo
Edited 2 time(s). Last edit at 04/13/2012 10:38AM by spikemichael.
MG CALENDARS! MGB or MGA order TODAY!   – Athol, MA USA $20 delivered anywhere! Visit www.mgbcalendar.com or CALL 617-674-4367
Adrian Page
Here's a link to the ones I found. http://www.crateparts.com/rockers.html
They seem to claim about 3 hp increase from what looks to be about a 35 thou offset.(just me guestimating)
david reynaud
fargo, nd, USA   usa
Hi Hap,
Thanks for your reply. Are you saying that Brown and Gammons sell the Titan RRs bushed, not fitted with roller-bearings, and with off-set shafts, complete with pedestals? smileys with beer
Thanks,
Dave
David Crosby
In reply to # 2039063 by spikemichael I would trade 10 HP for 10 lbs of torque any day.
When I bought them from APT I asked Dave how to line them up and he said,"It's not critical". But I measured and marked them before I pressed them in so they would all be lined up the same as close as I culd get them.
