What's that screeching noise?
Posted by Podalane51
Podalane51 Avatar
Lane Poole
Burleson, Texas, USA   usa
Pulled the carb and manifold off of the 1800 and replaced the side panel gaskets. When I put it all back together, there's this screeching noise coming from the front of the engine. Not the water pump or the alternator. Vacuum leak? Any ideas?
joels55 Avatar
Joel Slavick
Billings,MT., USA   usa
1964 MG MGB
1969 MG MGB GT "Franken B"
1978 MG MGB
Roger,did you pull the exhaust loose too,wondering if it's an exhaust leak. did you use a new intake/exhaust gasket at the head? also could be the dougnut gaskets at the down pipes coming off the exhaust manifold. Joel
Podalane51 Avatar
Lane Poole
Yeah, Joel, I took all that loose. Maybe I should tighten it up some. My catalytic converter is nothing more than a tube due to all the insides rotting out, but I don't think that has anything to do with it. I'll check my exhaust. Thanks, Joel.
Edited 1 time(s). Last edit at 04/08/2012 09:36PM by Podalane51.
Clay Johnston
Mt. Olive, MS, USA   usa
Lane,
Quick check, remove the belt and see if the noise disappears.
rrmgb Avatar
robert schau
Reston, VA., USA   usa
Clay X2
Sir Winston Churchill
G.S.George PHD
Podalane51 Avatar
Lane Poole
Yep, took the belt off and still makes the noise. Thanks, Clay
Clay Johnston
Lane,
Does the screeching sound like a rubbing noise or hissing like a vac leak?
Front of the engine you say? Might try locating the noise with a length of rubber hose held to the ear.
Basil Adams Avatar
About 12 miles from Sears Point, USA   usa
Spray the belt with WD40 while it's screeching and see if it goes away.
Basil C. Adams
1956 MGA Coupe (Show Car)
1957 MGA Roadster (Driver)
1958 MGA Coupe (Racecar)
1959 MGA Coupe (unrestored)
1960 MGA Coupe (unrestored)
1960 MGA Roadster (Driver)
MKIII Elva Courier (E1056)
1967 427 Cobra
1972 Alfa Romeo Montreal
A coupla late MGBs
1960 Austin Healy BN7
More Cars than Brains
Podalane51 Avatar
Lane Poole
It's not the belt. I took it off and ran the engine and still the noise. It's not a hiss. It sounds like something is rubbing, but nothing is evident. I used a stethoscope and still can't seem to locate the problem.
Shofine Avatar
Litch Litchfield
Sequim, Washington, USA   usa
I had a similar experience when I rebuilt my 67 MGB engine; the squeal was intermittent (not constant) and sounded like a bearing squeeling from lack of lubrication. The cause: I had accidentally replaced the "vented oil filler cap" with a later model non-vented cap (they look very similar). This caused a vacuum in my oil sump created by the PCV valve which is connected to intake manifold vacuum. I believe in my case, the air was sucking in past the rear main bearing. Remove your oil filler cap and see if the screeching stops. -- Litch (Shofine)
johnbaz Avatar
john biggs
sheffield, england, United Kingdom   gbr
Hi
The clutch release bearing can make a screeching sound when it's lost all the grease and is running dry, I know it's actually behind the engine but if your ears are anything like mine (worked in a heavy foundry for 33 years) then it'll be hard to tell the difference confused smiley
Hope you get it sorted thumbs up
Cheers, John smiling smiley
Podalane51 Avatar
Lane Poole
Here is the conclusion of this topic: I pulled that metal heat shield off of the first and second manifold bolts, reattached the manifold, and "Voila"- the noise is gone. I pulled all that environmental junk off of the engine, and man does it hum! Thanks to all who contributed.
