split lock washers are junk?
Posted by michmark
michmark Avatar
Mark Bates
Michigan, USA   usa
Howdy all,
My brother referred me to this website that talks about the how and why of fastener loosening. The interesting aspect is their claim that in the 1960's, it was discovered that split lock washers are not only ineffective but seem to hasten fastener loosening. Any thoughts from the forum?
Bolt Science
Mark
underdog Avatar
Jim Underwood
Pittsburgh, USA   usa
1980 Triumph TR8 "Fabulous Trashwagon"
1999 Chevrolet Corvette "Darth Vader"
1999 Chevrolet S10 "Spare Change"
2003 Jaguar S-Type "Eleanor"
I've seen them break in half resulting in a loose fastener. These days I prefer to use blue locktight on fasteners I want to stay put. Nylocks are also effective but can lose their grip if reused.
gooser Avatar
Drake Myers
Danville Va, USA   usa
what is going on this morning? split lock washers are junk? dot 3 and dot 5 brake fluid can be mixed? next you guys will be saying that the earth isn't flat. i'm scared.
twigworker Avatar
Jack Austin
Blowing Rock, NC, USA   usa
Didn't read the article yet, but my experience tells me that new split washers MADE OF GOOD MATERIAL work well in the right applications. I did have a TR3 come into the shop once with big lock washer under the cylinder head nuts. What a mess that was, but that isn't a "right application".winking smiley
My take is that if the washers are new or used with lots of "spring" left in them with sharp cutting edges they will work fine.
I am always a little suspect of published things that go off on esoteric tangents based on unusual test applications or lab experience. The best way to deal with this sort of thing IMHO is to read and learn what you can and then carefully apply the information to you real world situations with generous attention to your own experience of what works and what doesn't.
Jack
---------------------------------------------------- Services to Interesting British Automobiles-- www.jackscars.net ----------------------------------------------------------------
Jacks Cars - Services To Interesting British Automobiles Over 40 years of caring and capable services to British cars and their owners. For help or advice please call 828-295-0224, email to jackscars@charter.net or go to www.jackscars.net.
Jim1971 Avatar
Jim Smith
Cassidy, BC, Canada   can
When working on the cars I always replace the old lock washers, bolts and nuts with new ones. If there is no lock washer Loctite blue is always used.
Jim...Nanaimo, BC
1971 MGB collector
1975 MGB driver
1975 MGB in pieces waiting for V6
2005 Mini Cooper
A wise man overhauls his brakes before his engine.
EW Chapman Avatar
Earl Chapman
Ottawa, Ontario, Canada   can
Split lock washers are used often in aviation, so I'd question the actual research that says they're ineffective and promote the loosening of something. If this was the case, they would have been banned years ago, and the MIL spec for the washers would be cancelled.
If I had to guess, I'd say that the efficacy of a split lock washer probably has more to do with what it's made of and how it's made. I've never run into an occasion where one has worked loose, unless of course you reused a lock washer that was already flattened and didn't have the ability to lock in the first place.
Nylock nuts can also safely be reused without issue. So long as effort is required to overcome the friction of the nylock insert of the nut as it's being put on, it will do it's job. It becomes quite obvious when they're worn out and shouldn't be re-used. Just my $.02
spikemichael Avatar
Michael Caputo
Athol, MA, USA   usa
1973 MG MGB "Freebie"
1976 MG MGB "B-4"
1979 MG MGB "MegaBeanie"
1989 Suzuki Intruder 800   → more
In reply to # 2033680 by gooser what is going on this morning? split lock washers are junk? dot 3 and dot 5 brake fluid can be mixed? next you guys will be saying that the earth isn't flat. i'm scared.
It isn't.
It is hollow.
Hollow
Michael J. Caputo
MG CALENDARS! MGB or MGA order TODAY!   – Athol, MA USA $20 delivered anywhere! Visit www.mgbcalendar.com or CALL 617-674-4367
BritishV8 Avatar
Curtis Jacobson
Longmont CO, USA   usa
I don't use split washers, ever, and haven't since I was taught not to in college many years ago. I use hardened flat washers under both the head of every bolt and under every nut. I also use a lot of cinch nuts and/or nylon lock nuts. The only application I can see for split washers is when used for clamping soft materials together, where it's impractical to tighten the bolt up to its full torque spec - but in those cases I think Loctite is a better idea. Where a bolt is torqued up to its spec, split washers can't do much one way or the other since they're already squeezed dead flat.
RAY 67 TOURER Avatar
Ray Marloff
Fort Bragg, CA, USA   usa
1967 MG MGB "My Girl"
They work just fine when new, but if you try to reuse one, that has been under tension for 30+ years, failure will most likely occur. I've never had one lose its tension and cause a nut to come off. RAY
Gerry Avatar
Gerry Masterman
Prairieville, Louisiana, USA   usa
I rarely will reuse one. I have gotten my hands on some without any tension new from the store. BlueLoctite is my standby as well
Ray Marloff
Gerry, I use blue Locktite as well, but I've had good luck with split lockwashers over the years. RAY
