Body repair
Posted by JohnMacks
JohnMacks Avatar
John McAneney
Upstate NY, USA   usa
1976 MG MGB
Hello all, I started to sand some good replacement doors and came across some pin hole rust, very small and very few. What would be the best way to repair? Thanks in advance, John
John D. Weimer Avatar
Cape Girardeau, MO, USA   usa
A lasting quick fix would be to fiberglass the area from on the back side then normal finish work on the outside.
AHark Avatar
Andy Harkness
Pittsburgh, USA   usa
or reskin the door. Cost is about $100 for the skin, not a bad job and you have a full cross section of steel when you're done.
GTgeezer Avatar
Lynn Kirkpatrick
Indiana, USA   usa
Look farther, where there is a little rust, there is likely more rust. Then decide.
pooch2 Avatar
aussie 1968 MK 1
By the Beach, south coast NSW, Australia   aus
The door skin is about .035 thick.
If you see rust on the outside, that means that .035 of metal has rusted away from inside.
Like the tip of an iceberg.
What you don't see is what's under the water.
If it is only pinholes and not joined up large holes, AND you were able to sandblast the rust inside completely away, JDW/s advice would suffice if you don't want to weld in a patch or reskin.
j-blueridge Avatar
Jamie Bourland
C'ville VA, USA   usa
1968 MG MGB GT "Antichrist"
For what it's worth I re-skinned a door and found it to be pretty easy. The I carefully sanded (4.5" grinder with sanding disc) away the folded edges of the old skin until the metal broke away. Took of old skin. Put new skin on and folded over frame with sheet metal hammer. Tacked with a few welds behind.
I had little holes behind the chrome.
NOHOME Avatar
Peter Plouf
London, Canada   can
Word to the wise. If you do decide to reskin a door, trial fit it before you tack the skin in place. Once the old skin is off, the door frame can twist and you get to joint the crowd of MGB owners whose bottom rear of the doors does not sit flush.
I wish the guy who did the door skins on the GT from Hell knew this!
j-blueridge Avatar
Jamie Bourland
C'ville VA, USA   usa
I did test fit it and, as I recall, it was sitting pretty.
Barrie Braxton
Sunshine Coast, Australia   aus
Pooch will correct me if I'm wrong but one of the best ways to find out the extent of any rust is to sand blast and then you'll see how many rust pinholes you've got. In the case of the door I'd do this from the inside out (not outside in). I had my wings sand blasted that way - revealed enough pinholes in the bottom of the dog leg to require a 6" x 3" panel being welded in.
CKD 11/66 first registered 8/5/67 owned since 3/77. Undergoing nut and bolt restoration. Tartan Red (now). 18GB +40 balanced with almost all new internals. Peter Burgess big valve fast road head. Piper 285. TT exhaust. ARP everywhere. 123 ign. Needham 4synchro c/r box. Stock rebuilt/replaced suspension. Superpro bushes. New brakes all round including all pipes in SS flex. Interior redone. CAMS approved roll bar and side bars. Lots more. Hybrid of o/e and show/fast road car. Not for sale - it's my toy!
The old NZMGBs Avatar
Paul WIERINGA
Auckland, New Zealand, New Zealand   nzl
I’ve re skinned doors. Taking them apart and getting the skin off is fun…..fitting and lining them up isn’t. Lining up a new skin in the established door hole is the worse bit.
Remove the rust from the back side of the skin, cut out the hole and weld up would be how I would do it.
Paul ;-)
9146 Avatar
rick dentel
yardley, pa, USA   usa
Skin it.
