Have you installed front/rear sway bars?
Posted by jameslo
jameslo Avatar
James L
Southlake, TX, USA   usa
There are several sway bar kits for MGBs for front and rear.
I'm thinking about this as an upgrate to my '79. I'm discovering that taking some corners is a bit more exciting than they really should be, and I'm hoping this will stabilize the car and reduce oversteer.
Have you put one of the kits on yours, and if you did, which kit, and what were the results?
chris Avatar
Chris Roop
Pendleton, OR, USA   usa
See if the car is tapped to receive the bolts that would hold the swaybar; I think that they all were. Then you would just need the front wishbones, swaybar, and both down links with u brackets and rubber mounts, all of which can be gotten used or new.
Roop's MG   – Pendleton, OR USA Check out the Vendors' Deals page for the clutch, brake, and water pump sale. Please email me at the business address for business concerns.
Soyokaze 72MGB Avatar
Ryan Foster
София, Bulgaria   bgr
1972 MG MGB "Bitty"
Often, people lower the car to the chrome bumper ride height as part of the package. Taking the car to the early suspension with lightweight new alloy wheels and modern sticky performance tires makes the car handle better than most new sports cars. If you need parts or help, try Sportscar Warehouse in Arlington as they should have 99% of the parts you would need in stock and would be able to do the conversion very quickly. I drove my red '72 B up and down 1709 a thousand times, so I hope to see your car too later this year.
TomBrooksuk Avatar
Tom Brooks
Leicester, Leicestershire, United Kingdom   gbr
Hi
I have a 7/8th front ARB on my 67 BGT and an original Ron Hopkinson rear ARB very happy with the results
The car does have uprated lever arms all round and red "race" poly bushes front and rear too, with standard CB front and rear springs (speed bumps are a problem if i lower it further)
The car oversteers v slightly in the wet but is extremely predictable and iv driven the car a lot of miles with this set up including from the UK to the Le Mans classic 2 years ago with no problems at all and that included 2 laps of the circuit there.
James as yours is a RB MGB there are more things to consider esp if lowering the car as well as it upsets the geometry (which to be honest isn't that bad on a normal road car) we are just completing a FP style 1976 GT race car and its had almost all the suspension variations you can put on a MGB since it was initially a road car when we first bought it, then a fast road tract day car now an all out race car. So if your considering any other suspension upgrades i would be glad to tell you what affect they are likely to have as its probably been run on our MGB before.
Tom
Barrie Braxton
Sunshine Coast, Australia   aus
Didn't the r/b come with front and rear as standard (to account for the handling characteristics induced by the heightened ride - I get confused. C/b cars only came with a front bar which wasn't standard equipment until November '66 - they never had rear bars and in fact you'll find most do not recommend a rear bar on a c/b - panhards and/or anti-tramp rods yes (if you're going racing) but not a rear bar.
CKD 11/66 first registered 8/5/67 owned since 3/77. Undergoing nut and bolt restoration. Tartan Red (now). 18GB +40 balanced with almost all new internals. Peter Burgess big valve fast road head. Piper 285. TT exhaust. ARP everywhere. 123 ign. Needham 4synchro c/r box. Stock rebuilt/replaced suspension. Superpro bushes. New brakes all round including all pipes in SS flex. Interior redone. CAMS approved roll bar and side bars. Lots more. Hybrid of o/e and show/fast road car. Not for sale - it's my toy!
chris Avatar
Chris Roop
Barrie, The r/b starting in 77 came with rear bars as std., don't know about the front.
Barrie Braxton
Chris my Robson circa 1977 notes that the '77 model year improvements included front and rear anti-roll bars (which I thought were added due to the ride height). As the book was printed in '77 it obviously doesn't record if these were subsequently removed for the '78 or '79 model year. My Haynes MGB history book includes updates for '78 and '79 and doesn't mention that they subsequently removed the anti-roll bars. I don't have Clausager. I guess I'm saying that I would have expected James' car to have them and that as he doesn't someone's removed them but I'm not as aufait with r/bs as I am with the Mk1.
mgbgts Avatar
Rob Meier
Johnstown Ohio, USA   usa
All (US spec at least) 79's came with front and rear swaybars stock. Start with making sure all the suspension bushings and components are in good order before modifying anything, you may find replacing worn bushing and such will give a satisfactory improvement. If not, then lowering the car a bit will help a lot as the higher center of gravity on the rubber bumper cars really was what lessened the handling capabilities. I've worked with a few guys in lowering thier rb cars, and they were all very satisfied with the improvement.
Dwight Avatar
Dwight McCullough
Ham Lake Minnesota, USA   usa
Yes. The 7/8" bar from Moss and the stock '77 in the rear. Plus camber adjustment, lowered 1 3/4"- 2"
Stock springs/original shocks
underdog Avatar
Jim Underwood
Pittsburgh, USA   usa
1980 Triumph TR8 "Fabulous Trashwagon"
1999 Chevrolet Corvette "Darth Vader"
1999 Chevrolet S10 "Spare Change"
2003 Jaguar S-Type "Eleanor"
In reply to # 2031045 by mgbgts All (US spec at least) 79's came with front and rear swaybars stock. Start with making sure all the suspension bushings and components are in good order before modifying anything, you may find replacing worn bushing and such will give a satisfactory improvement. If not, then lowering the car a bit will help a lot as the higher center of gravity on the rubber bumper cars really was what lessened the handling capabilities. I've worked with a few guys in lowering thier rb cars, and they were all very satisfied with the improvement.
X2 except I'm not a fan of the typical way these get lowered and I believe acceptable street handling cn be had without. I agree with getting everything in top condition...then a better wheel/tire package.
peter d Avatar
peter h
yorkshire, United Kingdom   gbr
1958 MG MGA Coupe
1977 MG MGB "Abomination"
Hi all
Dont know if this will help.
http://www.kewengineering.co.uk/upgrades4mgs/Drivetrain/lowering_the_rubber_bumper_mgb.html
I lowered my 77 but i found that once i had done that i had to remove the Ron Hopkinson rear ARB.With it It handled like an exwife.
Difficult.
Peter-Sherman Avatar
Peter Sherman
Melbourne, Australia   aus
Moss sell a 7/8-3/4 adjustable bar
Bruce Hopgood
Montreal, Quebec, Canada   can
I have a 1973 c/b roadster and was once thinking of installing a rear ARB. Bought it, life got in the way. Since was advised not to install, can't remember why, so there it sits brand new in the box, since the mid 80's. I can not remeber the manufacturere but it is yellow! Let me know if interested I can probably post a snap if helps.
Salut
Bruce
lewisrn Avatar
Bob Lewis
Danville, IN, USA   usa
1980 MG MGB "The "B""
FWIW my 80 roadster came stock with front and rear anti-sway bars. Those, combined with lowering the car 1 1/2 inches, a front suspension refresh and new wheels and tires make the car a delight to drive.
EDIT - I also addressed front and rear bump stops. If you don't do that after lowering, you are in for some rude bottoming out incidents. Ask me how I know!
Life is a state of mind.
80B - Engine overhauled 1/11, SU HS4's, O/D, all Speedhut gauges, cruise control, front & rear suspensions rebuilt, tube shocks on rear, Moss lowering kit, Bell SS Exhaust, Ed's 110 amp alternator, Schlemmerized distributor with Pertronix, LED tail lights, halogen headlights, Limey's fuse box & relays, etc., etc.
Edited 1 time(s). Last edit at 04/13/2012 02:23PM by lewisrn.
NewBRG72B Avatar
Rodney McLain
Greenville SC, USA   usa
2001 Mercedes-Benz SLK-Class "The SLK"
2004 Volvo V70 "The Wagon"
2008 Mercedes-Benz E320 "The Diesel"
Yes, uprated 7/8 in front along with V8 bushings.
