Castrol Edge 5-50 Synthetic
Posted by DB Wood
Rod H. Avatar
Amity, Oregon, USA   usa
1964 MG MGB
1968 MG MGB GT
In reply to # 2026683 by Scott P Where do people get away with calling a 50 weight oil "thin"? Are they reading it wrong?
There is a misunderstanding. Dan and Terry are correct, in that 5w50 and 20w50 should both be 50 weight at hot operating temperatures. The lighter weight at colder temperatures can only be a good thing, as oil pressure would be achieved sooner, and full lubrication quicker. I'd try it, except that I don't have to drive my cars when it's below freezing, and I have a full shelf of VR1 that I bought on sale.
To the pure, all things are pure...
'63 MGB
'68 MGBGT
'80 VW Vanagon Kombi
Terry Ingoldsby
Calgary, Alberta, Canada   can
Quote: Where do people get away with calling a 50 weight oil "thin"? Are they reading it wrong?
Clearly a 50 grade straight weight oil would be very thick. But in this case, we are talking about 5w-50. So, at cold temperatures the oil behaves like a 5 weight oil (in the "w" winter or cold test) and like a 50 weight oil in hot temperatures.
In actual fact, multi-grade oil is actually closer to being constant viscosity - hot or cold. I'm not sure if that makes it thick or thin. smiling smiley
If you ever try to pour 20w-50 oil in very cold weather, it has the consistency of honey! 5w-50 pours easily in very cold temperatures, but is no thinner than 20w-50 at full engine operating temperature. It is really the best of both worlds. Easy flow on startup with no breakdown at high temperatures. Plus most (all ?) of the 5w-50 oils I've encountered have adequate ZDDP for our engines.
Terry Ingoldsby
terry.ingoldsby@DCExperts.com
Ted Barron
Bowling Green Ohio, USA   usa
1974 MG MGB GT
I have used Castrol Syntec (Edge) 20w50 for the past couple years and have been pleased with my engine's performance. My local auto parts store has to order it for me.
I've always been uneasy about the wording on the label--"Increased antiwear additive to help prevent flat tappet camshaft wear" It doesn't mention zink/phosphorous and inquiries about what the additives are fell on deaf ears at Castrol.
I don't want an oil that helps prevent the wear--I want one that does prevent it. I just bought a case of Brad Penn 20w50 patial synthetic high performance oil that "Contains high zinc and phosphorous additive concentrations..."
Ted
9146 Avatar
rick dentel
yardley, pa, USA   usa
Somebody better call Porsche they recommend 0-40 Mobil1 for the Carrera.
Terry Ingoldsby
Quote: I've always been uneasy about the wording on the label--"Increased antiwear additive to help prevent flat tappet camshaft wear" It doesn't mention zink/phosphorous and inquiries about what the additives are fell on deaf ears at Castrol.
I think you are unnecessarily concerned. Castrol's website seems to be gimped right now, but the cached version of the page (on Google) shows the additive to be ZDDP. If/when Castrol's website recovers, you should be able to see the whole page at http://www.castrol.com/castrol/genericarticle.do?categoryId=82915470&contentId=7032644
This page doesn't show the level of ZDDP, but I know I found it before and I seem to remember it was ~1200 ppm (1150 seems to stick in my mind).
Terry Ingoldsby
Terry Ingoldsby
Here is a link (to Castrol's site) that seems to work properly.
Note that the new 5w-50 is the replacement for 20w-50 - and better in every way!
Terry Ingoldsby
trewjohn2001 Avatar
John Trew
Mallorca, Spain   esp
Being thinner when cold isn´t the 5w50 more likely to leak out onto your garage floor devil smiley
favedave Avatar
David Church
Saint Joseph, MO, USA   usa
1967 MG MGB GT "Marilyn"
1995 Ford Probe
1995 Ford Probe "The Probe"
It's a British Car, it will leak no matter what weight oil is used.
Personally I favor parafin-based straight 30-weight from Big Lots for $.99 a quart. But my GT is a bit more persnickety so I pander to it with Castrol. (I wish it still smelled like it did in the 60s)
DB Wood Avatar
Daniel Wood
Bend, OR, USA   usa
1969 MG MGB GT "Clyde"
1970 MG MGB GT
I think the 5 number is scaring a lot of people. We have seen 5wt oil pour like water at room temperature, but that is not what happens in the 5-50wt oil. It will pour like 5wt at 0 degrees F, and act like a 50wt at 212 degrees F. That means that in the temperatures, in between, the oil has the viscosity somewhere in between the two extremes. At 100 degrees F it might have the viscosity of a 30 wt at that temperature. I just have to look at the oil pressure gauge to know what's good and what's bad. My combination gauge is the best gauge there is. It can show you things, if you know what to look for, that no other gauge can, due to the fact that it is un-damped and very accurate. All the other oil pressure gauges in the B's over the later year are crap. There, I said it, and it's my opinion of course. The UK cars I believe kept that gauge to the end, does that tell you something? 5-40 and 5-50 are great for our cars. Some have said they leak or burn, but that has not been the case with mine.
Dan Wood
70BGT driver, OD, Pertronix, HS4's, Peco, .060 over, Elgin cam, Superlite wheels, poly bushings, panhard rod, rear tube shocks, 1" lowered front end, HD shock valves, etc, etc.
69BGT project (V-6?)
88 Saab SPG Turbo
86 Vanagon Westy (South African conversion engine 2.0 OHC 135HP)
Lucas= Loose
Unsoldered
Connections
And
Splices
trewjohn2001 Avatar
John Trew
Mallorca, Spain   esp
Thing is the synthetic oils are expensive here, will they extend engine life? If I'm spending that much more on oil changes in the long run the money saved using dyno oil would pay half the rebuild costs. Or is it safe to extend the oil change intervals like modern cars do? I'm sure synthetics are good but is most rod bearing wear down to design of the engine or the oil were using? If the 5w50 flows like hot 20w50 on startup that has to be a good thing?
Jim1971 Avatar
Jim Smith
Cassidy, BC, Canada   can
I use full 20W-50 synthetic in Green B. The reasoning is that in very hot weather when the engine temp is just above the N the oil lubricates well and isn't suppose to loose its' properties due to high engine temperatures.
When we went on a road trip in May that involved a OAT of 10 degree F, coasting down a long mountain road and the engine cooled down to 1/4 of the way between N and C the oil pressure stayed consistent.
Synthetic will lubricate better thru a wider range of engine operating temperatures.
The stuff is a lot slipperier than dino oils.
Oil and filter changes are still every 4000 miles.
The synthetic oil doesn't leak from the engine either or end up going out the exhaust.
Jim...Nanaimo, BC
1971 MGB collector
1975 MGB driver
1975 MGB in pieces waiting for V6
2005 Mini Cooper
A wise man overhauls his brakes before his engine.
Terry Ingoldsby
Quote: I use full 20W-50 synthetic in Green B. The reasoning is that in very hot weather when the engine temp is just above the N the oil lubricates well and isn't suppose to loose its' properties due to high engine temperatures.
You are correct about the virtues of synthetic in hot weather (or if the engine overheats). Given that you encountered quite cold temperatures in your trip, you might have preferred the 5w-50. All the benefits of 20w-50 in hot conditions and much better performance in the 10F temperatures.
Terry Ingoldsby
