Cold Air Intake?
Posted by herculesmgb1971
herculesmgb1971 Avatar
gerard boulanger
Hercules, CA, USA   usa
I have a Weber 45 DCOE with a K&N air cleaner on it.
I am considering to bring fresher air into the carb from the front side of the radiator (next to the oil cooler and horn) instead of from inside the very hot compartment next to the exhaust and hot air moved from the fan.
I know it's a theory... And I am not racing...
A flexible hose could be installed through the existing 2-inch hole located on the radiator's mounting plate. I am thinking of the K&N RC-1090, since the room is limited, maybe one inch larger.
See the pics about the carb and the hole.
What do you think?
Any suggestions?
Thank you, Gerard
Be Coming Avatar
Kelvin Dodd
So. Calif., USA   usa
1957 MG MGA
1957 MG MGA Coupe
1958 MG Magnette
1959 MG MGA
1962 Morgan 4 Seater   → more
Gerard.
The factory made the hole through the radiator diaphragm bigger and installed a 3" diameter hose through to the grille area on some of their MGB race cars.
K.
kawtoy Avatar
Shane Nudds
Henrietta, NY, USA   usa
The effort and cost of making a cold air kit will far exceed the results. It has been discussed on here a few times before and I think the general though is not to bother. The money and effort can be better used in many places on the car. For instance the MPG gains (talking 1/4 mpg or so) can be equaled or likely beat by simply repacking the wheel bearings. It will reduce drag and also ensure everything will last till next service interval. Remember that a cold air intake doesn't help performance much except at high speeds where more cold air is being "forced" into the engine. Even then we are talking 1-2hp at most, hardly worth the cost of the hardware.
gerard boulanger
OK,
Cost would be very low since I can make the whole thing myself including the sheet metal box to replace the one I have now with the flat K&N.
I guess you are right, it doe snot worth the effort probably...
Thank you.
mac townsend Avatar
Fairfield, CA, USA   usa
you may find this useful
http://www.mgrescue.com/documents/F0315AB5B6EC618BDF10C9E435BAF4F13BE97B09.html
1973 Roadster. A nice 50-footer!
SUs, Datsun 5-speed
MGB Tips and Tricks: www.mgrescue.com
kawtoy Avatar
Shane Nudds
That link made my head hurt. ME NO LIKE MATH, NUMBERS MAKE SHANE EYES TWITCH. ME LIKE CARS AND BOOBS.
favedave Avatar
David Church
Saint Joseph, MO, USA   usa
1967 MG MGB GT "Marilyn"
1995 Ford Probe
1995 Ford Probe "The Probe"
Follow Kelvin's advice. The trick part is keeping the air cool in traffic, not at cruising speeds. So you will have to build some kind of cool air box with insulation connected to the carb throats.
Go for it!
NNN
Norman Nalepa
Florida, USA   usa
1979 MG MGB "Chick Mobile"
Just make sure you put a screen in front of the intake. You dont want all kinds of bugs clogging the filter.
gerard boulanger
Good advice Norman, I guess I will put a thin 6x6 stainless steel mesh behind the grille
Thank you.
