rear axle nut-is there a secret?
Posted by wireman
wireman Avatar
David Gaffney
Key Largo ,Fla, USA   usa
1974 MG MGB GT "The Mistress"
Morning all,I haven't asked a question in a long time,but I'm stumped
Have the axle on sawhorses and taking the brakes and hub off to do new seals. I cannot get the axle nut to budge,I have it locked up with a bar to stop the turning and even with an impact wrench I can't get that damn nut to break free.tried socket and breaker bar w/a BFH, Even thought that it might be reversed thread and tried it,but nope,no luck. Any ideas?
Thanks in advance
Adrian Page
Nova Scotia Canada, Canada   can
Air wrench.
OOps... didn't read your post carefully enough. They were regular thread on my MGB.
Edited 2 time(s). Last edit at 03/19/2012 09:11AM by pinkyponk.
Adrian Page
Bigger air wrench.
wireman Avatar
David Gaffney
Thanks Adrian,tried the air wrench,maybe my compressor is to small.These aren't supposed to be torqued to a high spec are they?
Dick Moritz
Philly 'burbs, PA, USA   usa
David,
Like Adrian says, an impact wrench will spin it off. On tube-type axles as used on 68-up roadsters and all GTs, these nuts are all conventional direction threads, so lefty-loosey. You may need more air pressure for your gun. Also note that an air hose with a larger I.D. will deliver more power to the gun.
"Scotty! I've got to have more power!" winking smiley
Adrian Page
150 foot pound for the B. Then tighten more if you have to to get the pin in.
Mine zipped right off at 100psi on a Bluepoint 1/2" drive gun.
Edited 2 time(s). Last edit at 03/19/2012 09:13AM by pinkyponk.
lewisrn Avatar
Bob Lewis
Danville, IN, USA   usa
1980 MG MGB "The "B""
I used a long cheater bar on the end of a long 1/2" drive breaker bar. Had to jump on it, but it finally broke loose.
Life is a state of mind.
80B - Engine overhauled 1/11, SU HS4's, O/D, all Speedhut gauges, cruise control, front & rear suspensions rebuilt, tube shocks on rear, Moss lowering kit, Bell SS Exhaust, Ed's 110 amp alternator, Schlemmerized distributor with Pertronix, LED tail lights, halogen headlights, Limey's fuse box & relays, etc., etc.
Edited 1 time(s). Last edit at 03/19/2012 10:09AM by lewisrn.
ddubois Avatar
Dave DuBois
Bremerton, WA, USA   usa
Let the impact wrench hammer away on it nonstop for awhile. I was trying to get the UJ flange nut off of our 66 MGB and had to let the impact wrench run continuously for several minutes before it finally came loose.
Dave DuBois
1953 MGTD
1966 MGB
SU Fuel Pumps & More SU fuel pump restoration and conversion to solid state. Information and technical articles on SU fuel pumps.
wireman Avatar
David Gaffney
Thanks guys,didn't realize that it required that much torque ,good to know when they go back on. OK bigger compressor!
Basil Adams Avatar
About 12 miles from Sears Point, USA   usa
Make sure you knocked back the lock tab and then get a long breaker bar and stand on it. I don't think this is true on a late B but on some cars, one side is left hand thread and the other is right hand - ask me how long I tried to take a nut off before figuring that out!
Basil C. Adams
1956 MGA Coupe (Show Car)
1957 MGA Roadster (Driver)
1958 MGA Coupe (Racecar)
1959 MGA Coupe (unrestored)
1960 MGA Coupe (unrestored)
1960 MGA Roadster (Driver)
MKIII Elva Courier (E1056)
1967 427 Cobra
1972 Alfa Romeo Montreal
A coupla late MGBs
1960 Austin Healy BN7
More Cars than Brains
Adrian Page
Tube axle uses a cotter pin. Not sure about banjo axles. The tube axle has regular thread on both sides.
Clay Johnston
Mt. Olive, MS, USA   usa
Without an air wrench, the best way I've found is, remove the hubcap from the center of the wheel, remove cotter-pin, reinstall wheel, put car back on the ground use 1/2" pull-handle with about 4 feet of cheater-bar. As noted above, you may have to jump on the bar to break this loose.
Use plenty of anti-seize on reinstall.
I've never understood why this nut needs 150 ft-lbs since it has beveled mating surfaces, seems like serious over-kill.
Ralph 7h Avatar
Ralph Siebenhaar
Viersen, Germany   deu
I tried this too with the axle out of the car. Finally I blocked the half shaft and used a cold chisel. It worked very well this way and was a 5 minutes job then. Even the Nut could be reused after a little filing.
Ralph
geezer Avatar
charles durning
Magee, MS, USA   usa
1958 MG Magnette ZB "Chick Magnette"
Not all impact wrenches are created equal. A lot of those cheap impacts will barely remove lug nuts. Even with a bigger air compressor you may still have to use a larger ID hose and an impact with some umph. This one is a real workhorse.
http://www.tractorsupply.com/ingersoll-rand-reg-edge-series-air-impact-wrench-impactool-1-2-in-drive-236g-3433448
78mgb Avatar
White Wonder 78mgb
Minnesota, USA   usa
1978 MG MGB
In reply to # 2016225 by Basil Adams Make sure you knocked back the lock tab and then get a long breaker bar and stand on it. I don't think this is true on a late B but on some cars, one side is left hand thread and the other is right hand - ask me how long I tried to take a nut off before figuring that out!
Ok, I will ask how long it took you?
I found it out by twisting the lug nut off the rear wheel on my 66 Dodge Dart. A friend afterwards informed me that the car had left hand threads on one side and right hand thread on the other. The theory being that the rotation of the wheel would keep the lug nuts tight. It sound reasonable until you consider how little torque is applied during acceleration on the lug nuts. I have never seen another car with left hand threads on the lug nuts.
geezer Avatar
charles durning
Magee, MS, USA   usa
Actually left hand lug nuts were common for decades especially on Chrylser products. They were also the standard of the industry for trucks until the trucking industry switched over to hub poiloted wheels.
lewisrn Avatar
Bob Lewis
In reply to # 2016343 by geezer Actually left hand lug nuts were common for decades especially on Chrylser products. They were also the standard of the industry for trucks until the trucking industry switched over to hub poiloted wheels.
Yup - Fords from the 50's had them too. One of the things I learned the hard way working as a pump jockey/flat fixer in the early 70's.
RAY 67 TOURER Avatar
Ray Marloff
Fort Bragg, CA, USA   usa
1967 MG MGB "My Girl"
They also had L stamped on the middle of the studs. This didn't stop me from trying to remove them in the conventional way however. With age comes wisdom. Sometimes. RAY
