new fuel tank
Posted by Rumpointer
Rumpointer Avatar
Mason Corbin
Tempe, Az, USA   usa
I have just purchased a new fuel tank for my 1969 MGB from Moos Motors. The tank arrived in bare metal, with some type of coating on it. When asked, the Moss rep said that it did not have to be primed and painted-the coating would be enough. I live in Phoenix, Az so salt/rust will not be a factor. Has anyone else installed one of these tanks without any paint, and if so, what were the results? Thanks.
paulthebaker Avatar
Paul Ashman
Panama City, FLorida, USA   usa
1974 MG MGB "Twiggy"
Got mine from VB about 2 weeks ago, it is one of the Canadian made tanks. I just bolted it on, no prep was reccomended.
Paul in Panama City (loving those black rostyles!)
psdeevers Avatar
Pete Deevers
Green, Ohio, USA   usa
1970 MG MGB "Dad's"
I replaced mine 2 years ago with a "Canadian". No baffles in it, but I'm not racing. Any way I scrubbed it with Dawn to get rid of factory oil, then put truck bed liner on it. Was going to prep the area under (above) the tank, but found clean factory gray paint, so I just installed the new tank. If it lasts as half long as long as the original that'll be 20 years! Not bad. The original was not all bad, and was going to have it cleaned etc. and the shop I took it to pointed out a new fuel tank every 40 years is not too bad!
Pete
Pete Deevers
Green, Ohio
1970 MGB
"That goofy previous owner really goofed up this car,,,, wait a minute,,,, I am the previous owner!" (Really my dad who bought it new in June of 1970!, I started driving and working on it in 1978)
Barrie Braxton
Sunshine Coast, Australia   aus
If Moss gets theirs from the same supplier as Moss-Europe then I was told that they are powdercoated - this was for a #NRP2 http://www.moss-europe.co.uk/Shop/ViewProducts.aspx?PlateIndexID=230 - it's installed but yet to have its first drink.
CKD 11/66 first registered 8/5/67 owned since 3/77. Undergoing nut and bolt restoration. Tartan Red (now). 18GB +40 balanced with almost all new internals. Peter Burgess big valve fast road head. Piper 285. TT exhaust. ARP everywhere. 123 ign. Needham 4synchro c/r box. Stock rebuilt/replaced suspension. Superpro bushes. New brakes all round including all pipes in SS flex. Interior redone. CAMS approved roll bar and side bars. Lots more. Hybrid of o/e and show/fast road car. Not for sale - it's my toy!
rrmgb Avatar
robert schau
Reston, VA., USA   usa
AFAIK, it is made of galvanized material as well as coated w/something.
* be very careful when tightening hard line to tank. Hold the tank fitting with a wrench before tightening the compression fitting. This tank has a filter on the bottom of the pick up tube, right?
FWIW - I had two of these tanks FAIL at this connection to no no fault of my own.
If it were me, I would install the tank with 2 of the easier bolts on each side, leave the filler neck and sender off, put in 2 gallons of gas and check for bubbles in fuel flow at the filter hose in engine bay. IF no bubbles, proceed with installation. I'm not saying yours will fail this test, just trying to save a little trouble shooting in future.
RS
http://www.mgexperience.net/phorum/read.php?1,1974509,1974588#msg-1974588
Sir Winston Churchill
G.S.George PHD
Scott Martin
Wimauma, Florida, USA   usa
1979 MG MGB ~ For Sale ! ~
Just bolt it up and forget it for another 20-30 years.
Get a new sending unit, fuel filters and feel confident that there will be no more fuel storage issues.
Clean gas, hurray!
pleblanc1206 Avatar
Pierre Leblanc
Saline, MI, USA   usa
1974 MG MGB GT "Strider"
When I bought my '74 BGT nearly 5 years ago it had a similar replacement tank (bare metal with some kind of clear coating). Still looks like new with no signs of corrosion.
1974 MGB-GT: black-label overdrive, essentially stock engine but detoxed, Allison XR-700 ignition.
ERO
Rich Osterhout
Toledo, Ohio, USA   usa
did anyone put a drain plug in?RichO
Rumpointer Avatar
Mason Corbin
Tempe, Az, USA   usa
Thanks for your response
Mason Corbin
gerry22 Avatar
Gerry McNulty
Nevada, USA   usa
1971 MG MGB GT "Sick"
1974 MG MGB GT "Rusty"
1979 MG MGB "BB"
Mason,
I have a 74.5 that was bought new in Phoenix cars has been with me now for 8 years so all the time in the desert. The tank still is bare metal still bright and clean looking. Living in Phoenix you should have the same results. Don't toch the tank.
Be Coming Avatar
Kelvin Dodd
So. Calif., USA   usa
1957 MG MGA
1957 MG MGA Coupe
1958 MG Magnette
1959 MG MGA
1962 Morgan 4 Seater   → more
Paul.
It's the same external coating used on modern vehicle fuel tanks. It does not need to be coated, but it won't hurt anything if you wanted to paint it.
Kelvin.
Simon Austin Avatar
Surrey, BC, Canada   can
Personally, and this is just my opinion....winking smiley, I dislike the look of silver tanks visible on a vehicle. A lot of new cars have these. As much as I appreciate the coating applied to the tanks, the silver has to go.
There's quite a bit of a B tank that shows below the valance.
Rumpointer Avatar
Mason Corbin
Tempe, Az, USA   usa
Thank you for your response
Mason
Rumpointer Avatar
Mason Corbin
Tempe, Az, USA   usa
Mason
