What did you do to your MGB today?
Posted by Stretch GT
Buzz808 Avatar
Thomas B
Hawaii, USA   usa
Power washed the underside of the car. Need to scrape the undercoating off now. Prepping to remove a section of the outer wheel wells for repair. Separating the wheel wells from the fender will be a chore. It looks like the PO replaced part of the fender and welded it solid to the wheel well.
9146 Avatar
rick dentel
yardley, pa, USA   usa
Installing the fresh engine and trans in my son's 78B.
Buzz808 Avatar
Thomas B
Hawaii, USA   usa
Started wheel well repair, removed section of fender and wheel well. Partially installed patch panel. Ran out of welding wire.
Mike Greeno
Wichita, KS, USA   usa
Installed repaired heater motor and started to rip out drivers inner sill snd both floorboarda
oily-hands Avatar
Owen Frankland
Stockton on Tees, Cleveland, United Kingdom   gbr
1937 MG TA "Numbum"
1971 MG MGB GT "The Bruise"
2002 MG ZR
Called in to visit some friends. grinning smiley
Ignition testing made easy.
My You Tube Channel
mdubash Avatar
Manek Dubash
Lewes, East Sussex, United Kingdom   gbr
1968 MG MGB "Odysseus"
Got the car back from a complete front-end suspension rebuild and:
- Replaced U/S choke cable (much easier if you take the radio out first)
- Replaced missing tonneau pegs
- Replaced ugly 1990s radio with modern (but retro-looking) unit that plays tunes from my phone
- Fixed non-moving heater air flap
- Refitted demisting hoses
- Washed the car
- An MGB is never finished. And all those replacement part deliveries give your postman something to do...
- If duct tape doesn't fix it - you haven't used enough duct tape
Mephiskapheles6 Avatar
Corey Mason
Nestleton, ON, Canada   can
1967 MG MGB GT "Hot RatZ"
Got the crossmember welded in. Next, fitting the frame rail reinforcements.
~C~
A.F.& A.M., C.Tech
dangerous-dave Avatar
DAVE CHASE
Puyallup WA., USA   usa
Changed the front shocks. and oil...devil smiley
tourtelot Avatar
Douglas Tourtelot
Seattle, WA, USA   usa
1976 MG MGB "Heathcoat"
We drove to Mt. Rainier on a beautiful sunny Northwest day. A place that is surely worthy of the term "awesome."
D.
Douglas Tourtelot
Seattle, WA
1976 MGB
18GB-U-H 85005
David Witham
Warwick, United Kingdom   gbr
Finished soldering the Mega Squirt 1 V2.2 that I have been building. Now onto the loom and sensors for it. Going to run it for ignition, via dizzy and sigle coil, and datalogging only. Staying with the SU carbs.
Buzz808 Avatar
Thomas B
Hawaii, USA   usa
Drained the differential, removed cover, flushed with kerosene/autotransmission fluid mix.
Patioboater Avatar
John Magee
Wolverine Lake, Michigan, USA   usa
1976 MG MGB MkIII "FUN MG"
Oy, vey, what a fortnight! First the fuel system died a couple weeks ago. So I installed a new fuel filter, which didn't solve the problem, since no fuel was getting that far. So I had had my garage install a new fuel pump. (The real culprit! The Mr. Gasket solid-state pump had died, no doubt a death hastened by some very dubious previous-owner wiring.)
Then as I pulled out of the garage, the tail lights died. Then after getting the tail lights going again, everything on the ignition-switched fuse died. And then after I replaced that, the directional signals died.
Agggh!
But all is finally sorted, and I'm back on the road. Now it's time for a wee shakedown cruise to make sure it all hangs together, then a wash and wax, and then we're off to the Dream Cruise tomorrow. Hurrah!
Edited 1 time(s). Last edit at 08/17/2012 12:47PM by Patioboater.
oldredsel Avatar
Rick Crosby
South Dartmouth, Massachusetts, USA   usa
1959 Ford Country Sedan "Edsel Villager Station Wagon"
1969 MG MGB GT "Emma"
1997 Dodge Neon
2003 Chevrolet S10
2011 Subaru Forester
Went to MG Day at the Larz Anderson Auto Museum in Brookline, MA. About 120 miles on the trip odometer.
I posted some pics here:
MG Day at Larz Anderson Auto Museum, Brookline, MA PICS!
Rick
oldredsel Avatar
Rick Crosby
1997 Dodge Neon
2003 Chevrolet S10
Jackie and I took the back roads (New Boston, Mattapoisett, Long Plain, Gammons, Perry Hill, Mary's Pond, and Fearing Hill Roads) to sup at Qdobas in Wareham. . . And I bet those roads just made Steve (sws615) smile.smiling smiley
On the way encountered a '58ish Corvette and actually got a thumbs up from a driver of a Ferrari 308, and then met a TR3 and a RBB on the way back home. It was a good drive!smiling smiley
Rick
Buzz808 Avatar
Thomas B
Hawaii, USA   usa
Preserved the outer wheel well with rust restorer and undercoating spray. Repaired the rust in the right rear fender with a patch and welded, just need to check and final weld. Found the same rust on the right rear quarter panel window like I did on the left. Makes for alot of small metal piece fabricating
Bankerdanny Avatar
Daniel Palmer
Chicagoland, USA   usa
1972 MG MGB GT "Dudley"
1977 Honda MC Gold Wing
Tried to see if a seat I found from a late 80's Prelude would fit (no). Rebuilt the right rear brake wheel cylinder and replaced the handbrake cable. My brakes definitely seem to work better (although initial pedal is still a bit soft and I finally have a working parking brake.
Endeavor to Persevere
JohnTF Avatar
John F
Northeastern Ohio, USA   usa
1970 MG MGB
1970 MG MGB
In reply to # 2146231 by tourtelot We drove to Mt. Rainier on a beautiful sunny Northwest day. A place that is surely worthy of the term "awesome."
D.
Nice, the clouds always seem to block the view when I come around, same with Mt. St. Helens, make sure the cover is on the MG when Rainier goes, that ash will scratch the paint. ;-)
Regards, John
Orange-77 Avatar
Joe Torre
Tallahassee, FL, USA   usa
1977 MG MGB "Punkin"
In Florida we do things a bit backwards. In the summer we put the car up on blocks for annual maintenance and repairs (hopefully in an air conditioned garage). It's just to freakin hot to be out for a drive.
Over the weekend I started installing the new brakes: Slotted and cross drilled rotors, new calipers, new backing plates, new pads on the front and shoes on the rear. Next will be installing new seat belts and a new oil cooler. After that, new telescoping shocks? The list never ends.
newpaintbody Avatar
David Snowder
Napa CA, USA   usa
1969 MG 1100
i installed my weber again, round 2!! and tuned it up, found out i need smaller jets! now what to do with the 1 3/4" SUs?
Dwight Avatar
Dwight McCullough
Ham Lake Minnesota, USA   usa
Uh, well, ya know, ya might find sumbuddy to buy 'em........
In reply to # 2150409 by newpaintbody i installed my weber again, round 2!! and tuned it up, found out i need smaller jets! now what to do with the 1 3/4" SUs?
