What did you do to your MGB today?
Posted by Stretch GT
mccann2002 Avatar
Jerad McCann
Lee's Summit, Missouri, USA   usa
Removed the front fenders and got a suprize on the bad weld job of the PO, did some wire tracking its a cluster from the PO. lots of cuts and splices
PC Dave Avatar
David Atkinson
Port Clinton, Ohio, USA   usa
I started taking all the bright work off, I want to have my GT reprinted, are there folks out there who have left the chrome off of the sides? I am thinking it will look cleaner with the chrome off.
knewham Avatar
Keith N
Seattle, WA, USA   usa
1979 MG MGB "Hoppy Devil"
1995 Land Rover Range Rover
In many ways, I'm only just getting started on my 1979 $900 red MGB find last year. And yes this is my first post here. Maybe I'll have her at least back to working with replace clutch and brakes and fix lighting to enjoy her at least this summer. Whenever that plans on happening here in Seattle. Even my homeland back in England has had better weather weather than here!!!
Anyway, only half the guages work. The important ones thankfully. Did have my local shop port the heads to flow better at the exhaust. Have fresh pistons swapped out for upgraded compression but reading that this might make it too high given the 79 cyl head might have too low a cc and cause detonation. maybe the thicker gasket will help offset that?
so also while the motor is opened up, with fresh crank bearings on 80K miles ( previous ones showing the copper a little), my attention turns to whether to swap out and get the camshaft reground to an earlier engine profile for better power. so much info out there on the websites that it's sometimes overwhelming. goal is a well running car with better power than stock 79 by adding in goodies from earlier motors (pistons, fresh bearings, double springs, double roller chain etc.). But not really up for major super balancing work. Just a restored engine.
So not much actual work on the car, but absorbing all the discussion on this fabulous website and getting enough planning in to get her back on the road.
Question - I'm not used to the MGB transmission - when I drove it after buying, the clutch was almost toast. gear shifting was possible but slightly challenging particularly 1st...does this mean the synchro's for 1st/2nd need replacing or is this likely merely a side effect of a clutch on the way out? Just want to avoid a rebuild if I can on the transmission, but then again, the motor IS out of the car and getting the transmission wont take much more effort. I guess this infers another question - anyone replaced their synchro's themselves? I have rebuilt auto transmissions before so it's all lego(s) to me. Just asking in case it's possible without specialized tools and the home tinkerer can do it themselves.
Thanks folks. I'll post more pictures and info as I continue my journey into MGB ownership and visit with the Prince of darkess. I have met him before with my early 90's RRover projects so I am not afraid eye popping smiley
HumbleBee Avatar
Gord Field
Vancouver Area, BC, Canada   can
Welcome, Keith and thanks for the post.
If you already have the engine out, you might actually consider the balancing route. I had mine done, cost about $200 to have all the rotating components balanced, first statically, then dynamically. I can't believe how much smoother it runs. I'd do it again in a heartbeat.
The hard shifting into first gear could indeed be a byproduct of a bad clutch, especially if the car has been sitting for a time. My throw out bearing disintegrated shortly after I acquired the car. The clutch was pretty much new when I took it apart, but it had been sitting for couple of years which I believe contributed to the deterioration of the throw out bearing.
I see you are running headers rather than stock exhaust. If you want to improve their performance and cooling, you might consider having them ceramic coated. I did that to my stock manifold (which I read a few places was better than headers) and it made a considerable difference to under hood temperatures. Not only that, you can get it in a couple of finishes including 'new cast iron' and a cool, shiny, blingy silver.
I regard my car much the same as you seem to yours, as a fun, well-running toy, with a few modern or performance upgrades. Like electronic ignition, an excellent investment! I also dealt the Prince something of a death blow simply by upgrading my alternator. I went the 95 amp Saturn route, but you can get a 95 amp Lucas if you really want to. Compared to the stock 45 amp unit, the upgrade is awesome. Bright headlights, everything electrical works, well, and turning everything on causes no discernible drop in their performance.
Happy motoring....
G
dennis1978redo Avatar
dennis pierce
port orchard, wash., USA   usa
1979 MG MGB ""LIPS""
Hello, in reading your comments "G" ,I see where you changed to a 95amp SATURN alt. Was that certain model number and was it fairly straight away to accomplesh? thx for your time,dennis
Edited 1 time(s). Last edit at 04/12/2012 05:42PM by dennis1978redo.
speedy Avatar
Michael Terrell
Oregon, USA   usa
1975 MG MGB "The Little Engine That Tried"
1995 Jeep Wrangler "Little Engine That Could"
2010 Jeep Commander "People Hauler"
Didn't do anything to the MGB but did something for it.
Called my insurance agent and got the 94 Mazda MX3 removed and put the MGB on in its place. Cost me $15 more every 6 months due to non abs brakes and being a convertible.
I'm hoping the weather will do as its told tomorrow and I can drive it to work for the first time. (Not as many folks work Friday so I can park closer to the front door and keep an eye on her)
Should be fun :-D
Now if I get pulled over let's hope I get a nice cop that doesn't mind looking up the car with my policy #
1975 MGB
Weber Down draft
Electric ignition
4 speed non O.D.
Soft Suspension
Tight Steering somehow
New Brake lines
New Clutch Master/Slave
SEAFOAM!!!
dennis pierce
Finally got the drivers side seat in ! Feels like a milestone. (maybe a one seater!)
Pete W
High Ridge, MO, USA   usa
Went for a test drive after changing the idle jet on the weber and saw the temp guage
start to hit the "H" Shut her down and found my heater valve was leaking.
I was only a 10 min walk from home so was able to bring the other car, water & fix it.
I'm drilling that baby out tomorrow and putting a valve in.
yonbear Avatar
Andy Mathers
Brisbane, Queensland, Australia   aus
1972 MG MGB MkII "Bee2 (B2)"
Promised a co-worker before I retired, that when I got my B, I would take her for a spin. Drove back into town today, had morning tea with my friend and kept my promise!
Andy smileys with beer
Bankerdanny Avatar
Daniel Palmer
Chicagoland, USA   usa
1972 MG MGB GT "Dudley"
1977 Honda MC Gold Wing
Dropped off the spare radiator I got when I bought my car to get pressure tested. The leak in the original radiator is getting worse. Time to fix it before the temps soar.
Endeavor to Persevere
P.DAVID Avatar
DAVID WEYANDT
LAURELDALE PA, USA   usa
1974 MG MGB "" SHE ""
1979 MG MGB MkIII "Lil' White Dove"
1986 Honda MC Rebel
Polished,waxed and cleaned everything I could reach. To night is the first car cruise night at Jimmbo's in Reading, Pa. I would like to see more MGs there this year. They have two every month all summer.
"Behind every silver lining there is a dark cloud"
"Some mistakes are too much fun to only make once"
“The difference between genius and stupidly is that genius has its limits” Albert Einstein
You don’t get smarter as you get older. There is just less stupid stuff left that you haven’t already done.
A36
Zachary O
Washington, DC, USA   usa
1980 MG MGB MkIV "The MG"
1986 Ford Ranger Pickup "The Truck"
Pulled master cylinder and found the source of my brake issues!
Boatin Avatar
John Kinnane
Caringbah, Sydney, Australia   aus
1964 MG MGB MkI
1979 MG MGB MkIII "Molly"
2006 Volkswagen T5 2.5 Turbo Diesel "Graf Zepplin"
After pumping up the tyre to a respectable 26/28 the steering is much easier and the some rattles reappeared. Noticed the drivers door rattled but it turned out to just the latch plate on the body tightened. Problem solved.
Regards
John Kinnane
'Molly' '79 Tourer
dennis pierce
I'M IN PORT ORCHARD AND THE WEATHER IS GREAT !GOT MY CAR OUT AND ON THE ROAD FINALLY AFTER CHANGING INTERIOR FROM BROWM TO BLK. GOTTA PUT THE SEAT BELTS BACK TOMORROW.
Patioboater Avatar
John Magee
Wolverine Lake, Michigan, USA   usa
1976 MG MGB MkIII "FUN MG"
Hopefully sorted out the wheel rub on my right rear tire. Now I'll have to take it for a spirited drive to confirm. Work, work, work....
Patioboater Avatar
John Magee
In reply to # 2040168 by Patioboater Hopefully sorted out the wheel rub on my right rear tire. Now I'll have to take it for a spirited drive to confirm. Work, work, work....
And, hurrah, no wheel rub on the test drive!
Now, it's time for a celebratory Old Speckled Hen.
Bankerdanny Avatar
Daniel Palmer
Installed my freshly tested and painted spare radiator and discovered that all 4 of my tires were inflated to between 45-50 lbs (!) courtesy of the PO, but abetted by me since I apparently hadn't checked the inflation since I got it in December.
yonbear Avatar
Andy Mathers
Betcha the steering was light!
Andy grinning smiley
rundjk Avatar
David Kinsey
Virginia Beach, USA   usa
1980 MG MGB "Runaway"
Corroseal on the brake drums (outside, of course), and plastic polish for the front amber running/turn signal lenses. Then I hope to insulate that brake line that drops down right next to the exhaust manifold and pipes. Yikes! That thing is like 2" away from the absolute hottest metal on the whole car! (manifold is ceramic coated)
David
David J. Kinsey
Virginia Beach
Tidewater MG Classics
1980 MGB "Runaway"
quanzy Avatar
nik j
nice, nice, France   fra
I bought my first one ;-)
