What did you do to your MGB today?
Posted by Stretch GT
trcarrell Avatar
Thomas Carrell
Montrose, Colorado, USA   usa
Ordered new front shocks from World Wide Auto Parts. I had sent mine in to be rebuilt but they were in too bad of a condition. Received the replacements, real good shipping and packaging. Installed the shocks and went for a drive in the mountains here in western Colorado. 40 degrees outside, sun shinning and the top down. Doesn't get much better than that except for warmer weather.
Michael Breeman
Sunshine Coast Queensland, Australia   aus
Not exactly on my "B" but rather for my "B". Cleaned and workrd on a UNF/UNC tap and dye set I purchased from the USA on eBay.
Have undercoated the container they came and as soon as the fierce electrical storm which is pounding my town at the moment, I will spray on a top coat. The set should make my screws, bolts and nuts a lot easier to use!
Stretch GT Avatar
Andrew Stretch
Orange County, CA, USA   usa
1971 MG MGB GT "Red Dragon"
Checked the compression - 195,195,190,190 smileys with beer
Car is running beautifully...
forestghost07 Avatar
Marco Sinai
Florida, USA   usa
1972 MG MGB GT "Viajero"
1999 Chevrolet Blazer "Works For Gas"
Wow Andrew, compression from heaven, smileys with beer is right hehe. In my 8 months of owning PLT I havent checked - I'm deathly scared of finding out the worst; just don't wanna know yet.
Stretch GT Avatar
Andrew Stretch
In reply to # 1990360 by forestghost07 Wow Andrew, compression from heaven, smileys with beer is right hehe. In my 8 months of owning PLT I havent checked - I'm deathly scared of finding out the worst; just don't wanna know yet.
Haha - I know the feeling. I was a bit nervous myself, as this was the first check. It was definitely a nice surprise when I saw those numbers.
Edited 1 time(s). Last edit at 02/20/2012 10:15PM by Stretch GT.
Dennis Ferron
Oklahoma, USA   usa
Returned a 72" battery cable to Walmart because it (the longest one they had) didn't reach from my battery to my starter. Pulled off the old DPO spliced-together cable to see if it was still serviceable. Measured it to be 60". confused smiley
oily-hands Avatar
Owen Frankland
Stockton on Tees, Cleveland, United Kingdom   gbr
1937 MG TA "Numbum"
1971 MG MGB GT "The Bruise"
2002 MG ZR
Sunday, took a short drive with a local club, about 80 miles round trip.
Stopped here for a while.
Ignition testing made easy.
My You Tube Channel
Michael Breeman
Hey Dennis, are you trying to confuse us? Have you been on the bottle?? The longer one was to short !?!? You should be able to make your old one serviceable as long as you solder any splices and insulate them really well. And while you're at it the terminals will most likely also benefit from a bit of attention. I'm sure you know all this but this advice may be of use to novice owners. Good luck, Mike
notyet-MG Avatar
Steve LaPaugh
Newport News, VA, USA   usa
Finally removed drivers side motor mount and bracket! Also a club member brought over a good used tan interior. I'm going to change from black to tan which will complement the Dansk Red better than black.
Bankerdanny Avatar
Daniel Palmer
Chicagoland, USA   usa
1972 MG MGB GT "Dudley"
1977 Honda MC Gold Wing
Well, I did this Sun-Mon-Tues night, but I replaced the rear springs and rebound straps and the related hardware and bushings and installed a new rear u-joint on the driveshaft and lubed up the front joint and slip joint.
Endeavor to Persevere
Marco Sinai
Florida, USA   usa
After doing about 400 fun miles last week, regretfully covered it up not to be driven till Sat while the new window tint cures. Its just too damn hot here this winter to have the windows up while driving. sad smiley
The tint job was the BEST I've ever had (I did do 4 hrs of prep for the guy though) Pics next week and kudos to David and Klaus @ Kustom Kar Sound and Tint, N. Miami Beach Fl. smileys with beer
Adrian Page
Nova Scotia Canada, Canada   can
In reply to # 1998163 by forestghost07 After doing about 400 fun miles last week, regretfully covered it up not to be driven till Sat while the new window tint cures. Its just too damn hot here this winter to have the windows up while driving. sad smiley
You need a smack.
speedy Avatar
Michael Terrell
Oregon, USA   usa
1975 MG MGB "The Little Engine That Tried"
1995 Jeep Wrangler "Little Engine That Could"
2010 Jeep Commander "People Hauler"
Last night I put in a new throttle cable and return springs.
A new choke cable and lever.
Installed a new air filter on my weber dd
1975 MGB
Weber Down draft
Electric ignition
4 speed non O.D.
Soft Suspension
Tight Steering somehow
New Brake lines
New Clutch Master/Slave
SEAFOAM!!!
Marco Sinai
Florida, USA   usa
In reply to # 1998173 by pinkyponk
You need a smack.
No Adrian we need a bit of proper winter here there's MOLD growing everywhere in Feb!! angry smiley
oldredsel Avatar
Rick Crosby
South Dartmouth, Massachusetts, USA   usa
1959 Ford Country Sedan "Edsel Villager Station Wagon"
1969 MG MGB GT "Emma"
1997 Dodge Neon
2003 Chevrolet S10
2011 Subaru Forester
Well today, she's in the garage.
But last week, the water pump started dripping slightly and the bearing showed a little play. So I installed a one on Friday.
Then on Sunday, I pre-ran the MG Coastal Tour route again that our local MGE group has scheduled for May 5, 2012.cool smiley It's a fun loop of @ 90 miles of back roads around the area and out to Sakonnet Point. Don't know how many MGs will turn out, but we already have @ two dozen that have expressed interest in joining us!thumbs up
Oh, and back to this past Sunday, the total miles added to the odometer were 162.smiling smiley A nice little drive!thumbs up
Rick
dr5669 Avatar
David Looy
Campbell River B.C., Canada   can
Sent a money order to purchase and ship an O/D trany for my 74 BGT from the east to the west coast.
Marco Sinai
Florida, USA   usa
Well since I vowed not to touch my GT till Sat to let the window tint set up, today I started trying to save the original (rust-covered) jack bag. DPO was an idiot. The buckles are history sad smiley The vinyl is responding to scrubbing with CLR - gonna take a few applications ...
I know they're available but there's only one original.
MGB 1976 Avatar
Mark Turechek
Central MA, USA   usa
1976 MG MGB "The Never Ending Project"
Installed a Jeff Schlemmer Lucas 25D distributor.
Jedster1 Avatar
Jed Jedrey
Hixville, MA, USA   usa
1969 MG MGB GT V8 Conversion "Yard Art"
1972 MG MGB "Roller Skate"
1991 Harley-Davidson Touring "Station Wagon"
2001 Ford F-350 "Wicked Black"
2002 Chrysler 300 "Jesus Chrysler"
Got caught in the snow we had today coming home from the shooting range! eye rolling smiley Top down, but bundled up. It was a blast!
Of course, now that we've had more snow and salt on the roads it won't be until after it rains again that I'll take it out.
Rick, let me know the next time you're going to run the route!!! I wanna go!!!
BTW . . . shot one inch groups at 200 yds and four inch groups at 500 yds, with one stray about two feet off.
From now on I'm going to stick to sophmoronic soft porn posts, and simply skip over topics I don't like. So there.
Edited 1 time(s). Last edit at 02/29/2012 11:16PM by Jedster1.
oldredsel Avatar
Rick Crosby
1997 Dodge Neon
2003 Chevrolet S10
In reply to # 1999000 by Jedster1 Rick, let me know the next time you're going to run the route!!! I wanna go!!!
Hey Jed!
Last Sunday's run was a last minute thing (I had to wait for a guy from CT to pick up those Autumn Leaf seats for his GT).
It's suppose to rain this Saturday (cleaning the roads!), but I think my day has been spoken for on Sunday. Will be in touch!
Rick
