Swivel Axle Top Trunion Bushings (are real bear)
rwsherman Richard Sherman
Massachusetts, USA   USA
My 1980 MGB recently failed a safety inspection due to excessive movement in the King Pins. I am in the process of replacing both front Swivel Axles with new rebuilt units from Moss. I got the old swivels out without too much trouble. Howver, I'm finding it extemely difficult to get the new top trunion bushings in between the shock arms.
After you press the bushing into the trunion, the total width is well beyond the width in the shock arm. I can't seem to compress the rubber enough to get them in. I did manage to do it on the right side using a lot of grease, but seemed to make a mess of the bushing in the process. I have had no luck on the left. I actually tore off a large piece from the edge of the bushing trying to get it in.
I'm suprised that I haven't seem anyone else having this problem. Am I missing something here? Is there a special way to get these bushings inserted?
Thanks for any help.
Rich
PapaMG Avatar
PapaMG John Shook
Colorado Springs, Colorado, USA   USA
1979 MG MGB "Tilley"
Deleted.. wrong application
John
Edited 1 time(s). Last edit at 2011-08-10 01:13 PM by PapaMG.
PeterC Avatar
Madison Wisconsin, USA   USA
The shock arm can be split. Undo the bolt about 3" inboard of the trunion, and spread the shock arms.
Peter
Supplying New Old Stock parts for all imports. A LARGE quantity being loaded to our EBAY store stores.ebay.com/worldwideimportautoparts Rebuilding lever shock absorbers for British cars. (800)362-1025 M-F 8-5 Central or parts@nosimport.com
rocannon Avatar
Inconveniently Located in, Oklahoma, USA   USA
1967 MG MGB GT "GT From Hell"
Loosen the bolt that clamps the two shock arms to each other. You can then spread the arms apart enough to slip the trunnion in quite easily.
Remember to tighten the bolt back up.winking smiley
TANSTAAFL !
lewisrn Avatar
lewisrn Gold Member Bob L
Danville, Indiana, USA   USA
1980 MG MGB "The "B"
Here is my super expensive gadget to make the job easy. Just loosen the bolt that holds the arms together and insert the larger bolt with nut between the arms. Use the nut to open the arms until the smaller bolt fits between the arms behind the larger bolt. Remove the longer bolt and insert the trunion until it is against the shorter bolt holding the arms apart. Now knock out the shorter bolt, line up the trunion and seure it with the trunion bolt.
EDIT- The longer bolt is 3" and the shorter is 2"
"Trying to get through to some people is like listening to the smell of the color nine."
Herb & Jamaal
It's how you react that matters. There's not a pill for maturity.
Edited 1 time(s). Last edit at 2011-08-10 03:09 PM by lewisrn.
100_0673.JPG    34.8 KB
rrmgb Avatar
Reston, VA., USA   USA
Well, I do the above too but jam a flat blade screwdriver between the arms.
But before that I make sure the shock link on top of the KP has been thoroughly cleaned of rust using a 1/2 round file. Then a bit of grease on the outer portion of the bushing and in it goes.
RS
Sir Winston Churchill
G.S.George PHD
Richard, welcome. Do as Bob suggests. I have a slightly different method in that I spread the shock arms with a bolt like Bob's placed where the upper trunnion pin goes - it needs a head and nut greater than the hole. Tightening the nut will spread the shock arms (don't forget to back off the bolt that keeps the shock arms together). The arms will only spread enough to get the upper trunnion and bushes in - the arms won't spread endlessly. I put washers into the gap that is created resting on that arm bolt and remove my spreader bolt. Lift the trunnion with bushes up and push trunnion pin in and then pull the washers out and then tighten to spec. If you put your finger in the upper trunnion you'll feel the kingpin and in particular the groove in the top of the kingpin. When the kingpin and top trunnion after perfectly aligned you will feel virtually no edge of that groove. Until the two are aligned you will not be able to get the bushes in correctly. The bushes need to butt up to either side of the trunnion (or very close to it) before trying to push the assembly through the shock arms.
MCCT Avatar
MCCT Charles Tisdall
New Zealand, Auckland, New Zealand   NZL
1967 MG MGB
1974 MG MGB GT
I just spread mine with a stubby screwdriver...all went well?
I did the screw driver trick but I found I needed a slightly larger gap between the arms than a screwdriver gave hence my method. It could be that my Superpro bushes have a slightly thicker collar than o/e.
The Brown B Avatar
The Brown B Rob S
Birmingham, USA   USA
1978 MG MGB "The Brown B"
Just out of curiosity, are you using the "V8" bushings with the steel insert? When I replaced the OE a few years back, there was no way I could get them to fit on my 78 rbb. I ended up ordering the poly bushings. I split the front shock to make them wider, used bolts, jam nuts screw drivers, etc. No problem with making them wider. The bolt would not tighten up. Not at all. I stripped the bolts and nuts. Had to order more. More downtime. Maybe my knuckleheadedness was the reason they would not fit. Dunno. But I have a set of "V8" bushings around here somewhere, new, unused.
Happy Motoring!
Rob my Superpro are a 3 piece - two bushes one steel tube (aka crush tube/piece). If you do not have the upper trunnion in complete alignment with the groove in the top of the kingpin then there's no way that you can compress the three to fit between the shock arms. Is the V8 set similar and might that have been the problem? I assume your poly bushes have a crush tube which begs the question if they fit why didn't the V8.
WOW! I never expected to get so many responses so fast. Boy, what a revelation. I never even thought of looking at the shock arm. I thought it was one piece. I guess that's because it's pretty covered with dirt and oil and I never really saw that possibility. I wish I knew this sooner, it would have saved me a whole lot of time and aggravation, let alone another new set of bushings. It was so frustrating that I suspected there must be an easier way and I was missing something obvious.
Thanks so much to all of you for your quick responses. I can’t wait to try it out once the new bushings arrive. I actually ordered 2 new sets from Moss, one standard and one poly. Not sure yet which I’ll use.
Rich
PS - I just turned 62 last June and have worked on a lot of cars over the years (brakes, exhaust, body, manifolds, and even valve jobs), but never did a front suspension before. I guess the mind isn't as sharp as it once was or I might have figured this out for myself.
PPS – Now can anyone tell me why my front steering seems to be almost frozen since I jacked up the front end?
Possibly you have no end float in the kingpins. There is meant to be .002" (and while that's next to nothing it is something). Inside the trunnion is a shim, a brass spacer and another shim on top - the spacer acts like a bearing. When the kingpin nut is tightened it should not clamp the trunnion to these hence the minute amount of endfloat. Now all that assumes that the shims (there are three thicknessess available with about .005" difference between each. If the shims aren't correct the kingpin will bind thus locking the steering especially when there's no load on it by being up in the air. That's my guess which is fresh in my mind given I've just gone through this in the last week of reshimming my kingpins and fitting bushes as well as springs and putting the whole shooting match back on the xmember (except wheel bearings etc) - that's tomorrow's job.
Edited 1 time(s). Last edit at 2011-08-11 05:35 AM by MGB567.
MGB79Tim Avatar
MGB79Tim Tim Lynch
Florida, USA   USA
I am wondering if all of this work is necessary when someone buys the standard or the premier set from the B-hive?
http://bhive.tierranet.com/200MGBFRONTsuspensionkits.html
I am hoping that all this is done by the B-hive and all I have to do it bolt the new stuff in...will there by any shimming needed on my part, or is that taken care of with this premier set?
Tim I suspect you would be right but check with Gordon. I had the issue because I took out the spacer and installed needle roller bearings so I had to adjust end float including making my own shims. It was trial and error (even with the use of a dial gauge) to increase the shimming until the kingpin didn't bind and I had correct endfloat.
