gear oil in transmission
jshepard77 Avatar
jshepard77 jeremy shepard
Maine, USA   USA
I changed the transmission oil on my '78 MGB last night. The oil I drained out smelled of gear oil, not regular 20W/50 oil. You know how gear oil has that distinctive smell? It smelled like that.
I'm not all that surprised, since I would have expected to put gear oil in there, until I read that MG's use 20/50 oil. So I bet the previous owner just put some in there.
Would gear oil in the gearbox cause any big issues? Car has always seemed to drive and shift OK before, and I haven't had a chance to test it out with the new oil. Is there anything I should keep an eye out for?
Not that it matters much, all I can do is use the right oil and maybe change it again in a hundred miles or so. I'm just curious if there are any bad side effects that could pop up later.
One interesting thing that I noticed as I got the car out of storage a week or two ago...with the car running and in neutral, if I let out the clutch the car would want to go forward a bit. Not like it was in gear...just wanted to drift forward. I guess that must have been from the heavy oil in the transmission. That effect seemed to go away after driving a bit.
1945 Willy's MB
1972 VW Beetle
1978 MGB
1979 Corvette
cfrantz Avatar
cfrantz Gold Member Chris Frantz
Mississippi, USA   USA
1957 MG MGA
1964 MG MGB
Sulfur gives gear oil that particular odor. Gear oil contains additives to combat the high contact pressures seen in tooth contact areas and sulfur is one of the chemicals/elements that has been used for years (over a century?).
Edited 1 time(s). Last edit at 2011-04-01 07:53 AM by cfrantz.
Ralph 7h Avatar
Ralph 7h Ralph Siebenhaar
Viersen, Germany   DEU
There is nothing wrong with gear oil in the transmission of a MGB. Although manuals say 20W50, the official British Leyland workshop suplement for the BGT V8 says gear oil for the V8 although they share the same internals and are only different in the bell housing and some ratios.
BTW, the V8 was delivered with OD only.
In my Roadster, I tryed gear oil many years ago (1978 mod. OD gear box fitted) and have not had any issues since.
kellybell Avatar
kellybell Kelly bell
Atlanta, USA   USA
1972 MG MGB "Mr B"
1975 Porsche MGB
2000 Volvo S70
I have always put gear oil in my gearbox - no issues.
twigworker Avatar
twigworker Jack Austin
Blowing Rock, NC, USA   USA
Always a big deal debate on this.
One side says 30wt non-detergent motor oil because it is safe for brass things inside.
One says gear oil for the pressure qualities for the teeth themselves.
Another advocates multi-vis motor oil because they think that it gets to the bearings and gears faster.
Still more want something to use any sort of motor oil because it flows through the OD passages easier.
Some car manufactuers spec motor oil and some spec gear oil for each of their transmissions and ODs when they have essentially the same innards.
To each his own, but for me any of the motor oils will do just fine as will the gear oil. The only exception might be that in very cold climates I might lean toward motor oil simply because it bothers me to think of the really gooey stuff being forced through the OD pump and valving when it is twenty degrees.
Jack
balloonfoot Avatar
balloonfoot Lloyd Faust
Southlake, TEXAS, USA   USA
Factory service bulletins say gear oil is fine.
jshepard77 Avatar
Maine, USA   USA
Great info guys...thanks.
I did notice that the car did want to creep forward with the clutch out in neutral. I'm in Maine and it's been in the 40's, so perhaps that cold temp was making the gear oil really viscous and causing the car to creep. It will be interesting to see what the 20W/50 that I put in does. But, we got 4 or 5 inches of snow last night...so that test will have to wait.
1945 Willy's MB
1972 VW Beetle
1978 MGB
1979 Corvette
Davenport, Iowa, USA   USA
I don't think modern multi vis oil would harm a gear box but i doubt it is any better than non detergent straight 30 weight. Just doesn't make a lot of sense to dump in a load of engine additives into a transmission unless they share the same oil bath ala Series A Minis.
The only "debate" I have run across is some feel the grease doesn't allow the synchros to work as well as they should.
I'd rather talk about who has the cutest grand kids than debate best oil or gasoline...because I already know the winner of the grand kids debate devil smiley
Regards,
Robert Kirk
kirkbrit@yahoo.com
Business phone 563 323 1017
cell 563 940 1864
http://kirks-auto.com/
Moss distributor/UK importer
bills Avatar
bills Bill Spohn
In reply to a post by kirks-auto The only "debate" I have run across is some feel the grease doesn't allow the synchros to work as well as they should.
Yup, and one other - use gear oil, or indeed anything thicker than a straight 40 wt. and the OD doesn't function well until the gearbox warms up.
You can use hypoid oil, engine oil or even automatic transmission fluid (as per BW T-5 specs) pretty much interchangeably in most manual gearboxes.
2007 BMW Z4M coupe (340 bhp)
North Vancouver BC
Proudfoot Avatar
Proudfoot Mark Stoltzfus
Amish Country - Ohio, USA   USA
Here is a link to a short article written by someone who works on them though it is more overdrive specific. I thought it was a good read. http://www.quantumechanics.com/categories.php?op=newindex&catid=11
Edited 1 time(s). Last edit at 2011-04-01 11:00 AM by Proudfoot.
BobG Avatar
BobG Bob Gohn
North Andover, MA, USA   USA
Don't forget ATF in OD gearbxes on the list of debates / alternatives. Using it fixed my OD sticking issues, though I'll probably switch back to 30W or 20/50 oil.
FWIW - do look at the Quantum Mechanics test data for ODs. While I don't think this was conclusive on 30W NT vs. regular 20/50, it did seem to have some interesting justifications re: NOT using some other alternatives....
Bbo
ingoldsb Avatar
First of all, the viscosity ratings for engine oil and gear oil are different. 20w-50 engine oil is about the same viscosity as 80w-90 gear oil.
There are concerns with GL-5 rated gear oils - sulphur compounds that can hurt brass components - but I think the brass components were only used in early transmissions so that is probably not a problem for you.
This weekend I am changing to Redline MT-90 75w90 GL-4 gear oil. It explicitly states that it is safe for brass synchros. It also claims to optimize the coefficient of friction for synchros.
I question the 30w recommendation given by Quantum for OD transmissions. As far as I can tell, Quantum did not take into account the effect of temperature on 30W oil. It performed better than anything else they tested at one temperature. I would be interested to see how 30w oil would fare at temperatures below 0C (32F). Multi-grade oil is actually constant viscosity (or close to it). So it performs the same over a range of temperatures. If you live in California, the 30w oil probably works great for you. But if your car must deal with a wide range of temperatures use multi-grade. BTW - the factory recommended different multi-grade oils for different temperature ranges.
Terry Ingoldsby
terry.ingoldsby@DCExperts.com
bills Avatar
bills Bill Spohn
Terry, I'd add only that one should beware of using synthetic on OD transmissions, especially if you use them hard. I've seen several trashed OD units because of that. Otherwise, though, I really like the synthetics - it almost always give superior synchro action.
North Vancouver BC
Proudfoot Avatar
I would like to use the Redline oil too but I'm concerned about leaks. Now that I have replaced some seals and gaskets, if it holds 30W maybe I'll try the Redline after while.
In reply to a post by BobG Don't forget ATF in OD gearbxes on the list of debates / alternatives. Using it fixed my OD sticking issues, though I'll probably switch back to 30W or 20/50 oil.
Bbo
ATF is a powerful cleanser...don't know but suggest that may be the reason your OD stopped sticking. A lot of folks get het up about Marvin's Mystery. I sorta think I solved the mystery and use the not patented version with pretty much the same results.
Regards,
Robert Kirk
kirkbrit@yahoo.com
cell 563 940 1864
