Adjusting Toe In
Norm73B Avatar
Norm73B Gold Member Norm Peacey
Woodlawn, Ontario, Canada   CAN
1952 MG TD "Eileen"
I rebuilt my steering rack this winter and was considering an easier way to set the Toe In than on my back with a tape measure.
I was in a local garage (old fashion kind where the guys drink beer and drive flat head powered hot rods).
They had a 29 Ford roadster on the floor with strings tied to the inside of the back wheel spokes (wire wheels), wrapped around the tire and forward past the front wheels to a 2x4 fastened to the wall in front of the car. The strings where fastened to the 2x4 so they touched the front of the back wheel and ran past the centre of the front wheel. They measured from the string to the front and back of the front wheels, the difference was the toe in value for that side. Interesting they set the toe in at 1/8, the same as our Bs. Simple, easy, accurate and once the 2x4 is in place easy to reuse.
I will try it shortly but it just made so much sense. Will add pictures later.
Anyone else heard of this?
rrmgb Avatar
Reston, VA., USA   USA
All sorts of methods. FYI toe in spec is 1/16" - 3/32"
Scuff gauge works for me. Push one wheel on it and read the value, no strings attached. thumbs up smiley
Sir Winston Churchill
G.S.George PHD
mitchelld996 Mitch BGT
La La Land, California, USA   USA
The book says to have toe-in between 1/32 and 1/16.
rgoeckel bob goeckel
FLINT, MICHIGAN, USA   USA
1977 MG MGB "On The Road Again."
robert, i just checked on the scuff gauge. kwik-ezee said they were $225.00eye popping smiley. but they are not making them anymore. if that is what you were talking about.
Edited 1 time(s). Last edit at 2011-03-23 10:54 AM by rgoeckel.
rrmgb Avatar
In reply to a post by rgoeckel robert, i just checked on the scuff gauge. kwik-ezee said they were $225.00eye popping smiley. but they are not making them anymore. if that is what you were talking about.
Havent seen a kwik-ezee but probably works the same.
I just drive it to R&R and push it on! Always good to know someone who has one.
RS
G.S.George PHD
"r&r" ? i guess i'm a bit slow.
Jim Stabe Avatar
San Diego, California, USA   USA
Strings are a great way to set toe, especially if you have IRS. Racers will "string" their cars from a datum established from the centerline of the suspension pickup points so all corners of the car are square to the vehicle centerline. The problem is that it is time consuming to set up the strings. You have to locate the centerline then set up the outer strings equidistant and parallel to the centerline. After you do that, you can't move the car without setting it up all over again.
I am building a string setup into my car so it will be quick to set up and be repeatable. It will also allow the car to be moved without disturbing the strings. After adjusting the toe you should roll the car back and forth to settle the suspension and then remeasure.
I welded 1/2" nuts onto the bumper support so that I can screw in the brackets that hold the tubing front and rear. The brackets are designed to hold the tube at hub height at each end of the car. The tubes are 1/2" electrical conduit that have a groove turned at the center and grooves at each end to locate the side strings. The end grooves are equidistant from the centerline, both front and rear tubes are identical. To set it up the first time I put the car on a level surface. I set up a string on the centerline of the car that was equidistant from the front and rear inner pickup points of the suspension (I have IRS but a solid axle car could use the front spring hangars). I then adjusted the tubes back and forth in the brackets so that the centerline groove was directly over the centerline string (use a plumb bob) and locked the tubes in position with the thumb screws. When I had the tubes centered perfectly, I welded a washer to the tube on the driver's side of the bracket so that every time I assemble the rig it will be perfectly oriented to the centerline of the car. The car will then not have to be on a perfectly level surface to do the check.
You then run strings between the outer grooves and you have a perfect rectangle and you can measure directly from the string to the wheel rim. If you want to be deadly accurate you can spin each wheel and scribe a line on the tread. The toe specification is actually measured at the OD of the tire. If you know that your wheels run true you can do the math for what the measurement at the rim should be since it is much easier and quicker. You can roll the car back and forth to recheck your adjustments without disturbing the strings.
This is good for the autocrossers who want to dial in some toe out for the event and then set toe in for the drive home.
Alignment 007.jpg    37.6 KB
Alignment 008.jpg    47.7 KB
Alignment 009.jpg    26.4 KB
Alignment 010.jpg    40.5 KB
Alignment 011.jpg    48.6 KB
Alignment 012.jpg    37 KB
Norm73B Avatar
1952 MG TD "Eileen"
I will need to check as I do not know what a scuff gauge is.
I read somewhere that for radial tires the toe in should be 1/8 instead of the 1/16 to 1/32 for bias ply.
Can anyone confirm/correct me.
Norm73B Avatar
1952 MG TD "Eileen"
Jim, that is very interesting.
I wonder if one cold be made up that could be moved from car to car.
I will think about that.
Jim Stabe Avatar
In reply to a post by Norm73B Jim, that is very interesting.
You could do it but you would have to make sure that the brackets that the washer butts up against are exactly the same distance from the centerline on both cars. The brackets on the other side of the car aren't improtant. If they are two different kinds of car, just make sure the strings are wide enough apart to accomodate the widest vehicle.
Norm73B Avatar
1952 MG TD "Eileen"
Jim, I was thinking along the lines of the 2x4 but using your 1/2 inch conduit.
Each time I would have to set up to the back wheel first then measure the front.
Must be an easier, repeatable thing I can make that others could use.
Back in the 60s we had a square tube with adjustable legs and a fixed bracket on one end and a movable bracket on the other.
The thing was setup so the fixed bracket hit the mid point of the outside sidewall of the front tire and the movable one was fixed with a butterfly nut against the same point on the other front tire.
Move to the front of the wheels and measure the difference with a steel ruler.
Difference = toe in.
I wil have to think about that one a bit more.
Love the ideas from this place.
I do my own string alignments as well, nothing attached to the car, I made 4 hub center height platforms , if you will, but it cold be 4 jackstands as well, I measure the track F&R, it's not always the same on given car, then set the strings from the hub centers, once I have the car squared in the strings, I measure from the front and rear of wheel rims for toe readings. I use 4 squares of aluminum plate, I use two under each of the front wheels , with a mixture of grease and WD40 sandwiched between the paltes for cheap turntables (you can do the same thing 4 pieces of commerical tile). I have a very simple and cheap bubble camber gauge, for using on the cars I can adjust camber on.
You can do a alignment with very common and cheap tools if you understand what you are doing, we did this very thing at our last car club tech session.
Peter-Sherman Avatar
Peter-Sherman Peter Sherman
Melbourne, Australia   AUS
I just take it for a drive. Adjust adjust. then I drive it on tram tracks, if it is squeaking on the steel, there is too much toe in.
RSS Avatar
RSS Gold Member R SS
Northern, Virginia, USA   USA
1969 MG MGB GT
1971 MG MGB GT
2003 Saturn Vue
In reply to a post by Peter-Sherman ...then I drive it on tram tracks, if it is squeaking on the steel, there is too much toe in.
And if you hear rumbling, you're not going fast enough. eye popping smiley
Congress is proposing a bill that would give President Obama a kill switch that he could use to freeze all activity on the Internet if there were a national emergency. The kill switch goes by the top-secret name Microsoft Windows. –Conan O'Brien
GILMGA Avatar
CHATTANOOGA, TENNESSEE, USA   USA
1962 MG MGA
1974 MG MGB GT
I use a spring loaded curtain rod. Line up front and rear tires on driver side with laser leverler. Insert curtain rod on front rims same distant from floor,mark rim for reference, mark where slide edge is on curtain rod with then pencil,
rotate wheel to rear of then insert the curtain rod. Mark where the slide on rod is. The difference is toe. Adjust the oposite from side that is aligend with rear. Check front and rear wheel alignment with laser. Hope stering wheel is centered.
Gil
1964 MG Midget MkI
