Press fit piston wrist pin removal/installation
Tom Price Avatar
Tom Price Thomas H. Price
Brownstown Twp., MI, USA   USA
Ok folks,
Anyone got any helpful hints for the removal and installation of press fit piston wrist pins ('76 B)?
Seeing as I can't seem to find the Special Service Tool quoted in the service manual, I'm looking for viable alternatives.
Tom
Limey Avatar
Limey Eric Marshall
Pentwater, MI, USA   USA
Tom - you need a long piece of threaded rod that will fit through the wrist pin (gudgeon pin), a piece of tube about the same length as the wrist pin with an ID larger than the pin OD. Two nuts for the threaded rod, one washer with an OD slightly smaller than the pin OD and another washer with an OD larger than the tube OD. If the threaded rod nut is larger than the pin OD you will have to grind it down!
Now, put one nut on the end of the threaded rod, along with the pin sized washer. Put the rod through the pin, then the tube over the rod at the opposite end to the nut/small washer, then the big washer and another nut. Now CAREFULLY tighten the nut on the tube end and it "should" pull the pin out.
You can use a similar arrangement to get the pin back in!
Eric Marshall
Bits4Brits
Jim1971 Jim Smith
CASSIDY, BC, Canada   CAN
Would this idea work using the correct sized sockets and a fine thread bolt?
Gerry Avatar
Prairieville, LA, USA   USA
When you put things back together, throw your pins in your freezed for a couple of hours and heat the piston up to 250 degrees or so in an oven. Make damn sure that you have the rod/piston orientation right before pushing the pin in. Awwow to the front on the piston, squirt hole in the big end of the rod away from the cam
Limey Avatar
Limey Eric Marshall
Jim, yes it would. The only problem is finding a socket long enough to accept the wrist pin and a bolt roughly twice the length of the pin.
Eric Marshall
Bits4Brits
Steve F Avatar
Wylie, TX, USA   USA
Post Edited (09-28-04 11:30)
Steve & Marilyn Fitch
1964 MK IV Farina
1966 B
1978 B
Jim1971 Jim Smith
Guess socket idea would only work for installing the pin. For removing the pin a tube long enough to receive the pin would be needed. Looks like another project for the guy that I know that has a lathe.
Tom Price Avatar
Thanks for all the advice, that'll help.
Has everyone who has done this job made such a tool?
chris Avatar
Pendleton, OR, USA   USA
Some of us revert to older rods and pistons to avoid it. smiling smiley
Used English car parts.
Tom Price Avatar
Can older rods and pistons be used in a later car?
I thought there was a combustion chamber difference in the early and late heads.
Gerry Avatar
Rods have nothing to do with combustion chamber differences. I refuse to use 18V rods in any engine I build. I use 1971 and earlier rods,with the slip pins, instead.
