Replace Transmission rear oil seal and speedi-sleeve - Complete
mitchelld996 Mitch BGT
La La Land, California, USA   USA
I saw many related posts on the subject of the oil seal at the tail of the transmission. I too have an oil leak at the rear gear box seal so I'll be diving into this. I plan to go with the belt and suspenders approach of using a new seal and a speedi-sleeve even though I don't know the condition of the flange yet.
I couldn't find any details or pictures specifically about the use of the speedi-sleeve. Is the sleeve to be installed over the flange that is bolted to the driveshaft? I don't have the flange off my car at the moment so the only pic I have is this really pitted example that I found on the internet.
Does the speedi-sleeve go on the surface to which I'm pointing I assume I'd have to push the sleeve on only so far to ensure the oil seal contacts the sleeve.
Regards,
Mitch
Edited 2 time(s). Last edit at 2011-02-25 06:49 PM by mitchelld996.
Flange_very_bad_condition.jpg    30 KB
Sprite Lou Avatar
Sprite Lou Platinum Member Lou A.
Springfield, Oregon, USA   USA
1970 MG MGB GT "Higgins - RIP"
1973 MG MGB GT "Eliza - FIRST PLACE - MG2013"
1976 MG MGB "Daphne"
Contact Dan Hoerring (Dan-the-fit-man)... he just did this recently and has an excellent documentary on his work - (I believe PBS is in negotiations with him to aire it) smiling smiley
Danthefitman was a name of authority that kept popping up in the various threads on the subject. I couldn't figure out how to send PM with a picture. I'll PM him now and refer him to this thread!
Sprite Lou Avatar
Now you're talkin.... when I'm ready this spring for install, I will surely refer to his threads on the subject.
chris Avatar
Pendleton, OR, USA   USA
That was funny Lou. Unfortunately, the congress is talking about cutting PBS funding so I doubt Dan will get picked up. Which is really too bad as that would be a show to watch!
Used English car parts.
ozieagle Avatar
1958 Wolseley 1500 "Wooly"
1966 MG MGB "Bl**dy B"
Hi Mitch,
Speedi sleeves are easy. You need to remove the flange and take it to the shop with you, to make sure you get the correct one, diameter and width.
They come with an installation tool. With a vice to push the sleeve onto the flange the job is easy. NOTE you will need to coat the flange with a non drying sealing compound, such as permatek. You can probably get this at the same time as the sleeve.
Herb
Indeed! I did get confirmation from another MGE member that the speedi-sleeve will be installed on the flange in the location I'm indicating. I'm guessing my flange won't be anywhere near as bad as the one shown in the picture, but I'll be installing one anyway. It was also recommended that I use some compound under the sleeve too - sort of a foundation and/or seal for the sleeve itself against the flange.
Looks like the sleeve I'll need has a sealing surface width of about 5/8 inch so the other key to the install is to push it on the flange far enough so that the oil seal is sealing on the sleeve surface. I don't know the dimensions of the flange as yet since I didn't remove mine, but I'll be sure to measure carefully! Looks like these sleeves can even be had through Amazon for about $35USD.
When I get to it, I'll take pictures as appropriate and post to this thread.
MD
danthefitman Avatar
danthefitman Dan H
Portland, Oregon, USA   USA
A Speedi-sleeve on the flange at the tail shaft? Okay. I used the sleeve on the crank side. I didn't have wear/tear on my tail shafts on either gearbox, smooth and unscathed as a babies bottom.
I did the PBS special already - it airs tonight at 8 PST, Mr. John Twist is joining me too.
I did plenty of research too on speedi-sleeves. They're not hard to install - just take your time. They arrive with a tuna-type-can install tool which I tapped on with a large rubber mallet. When on smoothly and no leaks since - that over 2,000 miles ago.
My first thought is to have that tail shaft lightly turned on a lathe to smooth it out then put a new seal on, no speedi-sleeve.
dan@motorcardetailing.com or dan@fitnessintraining.com
the body is a temple, not a warehouse | for your body and your car
To be honest, I don't know that I need a sleeve on the flange. However, I'd rather do belt and suspenders (new seal and sleeve on flange). I plan to tackle this seal with the gearbox in the car - I'll remove the drive shaft and go from there.
Here's a pic showing the leak I currently have from this seal. Oil leaks out of this seal, then runs down the rounded back end of the OD and accumulates on the OD sump plate until it drips off. I hate oil drips! I'm a firm believer that all leaks can be solved. I've had numerous air cooled Porsches and I was able to solve all of the oil line and seal issues on those, and I was proud to have a dry garage floor! I'm not going to let the MG get the better of me in this regard.
MD
PS - that line on the flange that looks like a crack is not a crack. It's just the strongest score line I've ever seen!?
Transmission_rear_oil_seal.jpg    66.6 KB
danthefitman Avatar
danthefitman Dan H
Here's how I removed the nut and replaced the seal.
Dan's way of removing nut on tailshaft of Non-OD Gearbox - Spring 2010.JPG    71.7 KB
danthefitman Avatar
danthefitman Dan H
Here's another couple shots...
Non-OD tailshaft without flange or seal and Installation of new seal - Spring 2010 - Danthefitman.jpg    35.6 KB
Sprite Lou Avatar
Dan, you're MORE than welcome to pop down this way some weekend to do mine thumbs up
danthefitman Avatar
danthefitman Dan H
Removing the seal isn't tough, just patience-made. Once you remove the nut - the seal is ready to come out. It will be "in-there" because of expansion, contraction, though with a little time, nudging with a small flathead, being careful not to scratch the bore, she'll come out! Be brave, take your time. God knows, if I can do it successfully, anyone can! I didn't know a seal from a hole in the ground before last spring.
I learned so much - and it was mainly due to the courage instilled by this place. Once 'on the job' working on the B - I manned up and got'r done! I am quite slow, but I tell you what, I enjoyed every minute of that massive gearbox swap. I encourage all of you to do it! If could have polished the seals, I would have!
danthefitman Avatar
danthefitman Dan H
Here's what the DPO did to the old seal...in hopes of not trying to replace it...
Old seal and new seal - Spring 2010 - of Non-OD in Danthefitman's now sold, 77 B.jpg    41.5 KB
danthefitman Avatar
danthefitman Dan H
Feed me healthy food and you gotta deal Louis!
In reply to a post by Sprite Lou Dan, you're MORE than welcome to pop down this way some weekend to do mine thumbs up
Edited 1 time(s). Last edit at 2011-02-20 09:11 PM by danthefitman.
