Oil pressure & temperature gauge restoration
sultanoswing Avatar
sultanoswing Curtis _
Hamilton, New Zealand   NZL
1971 MG MGB GT "The 'Gee"
I'm tired of the intermittent working of the temperature gauge in my 1971, and the non-working nature of the temp. gauge in the 1970, so am going to pull 'em and get them restored.
They're both the alcohol capillary type, so likely need refilling and calibrating. The oil pressure and all other gauges in both cars work perfectly, so I don't believe this is a simple voltage stabiliser question.
In order to pull the gauge, I obviously need to temporarily plug the hole in the cylinder head where the water temp sensor screws in, and also the oil pressure line feed at the block, or at least where the oil line joins to the gauge.
So: What size / thread is the hole in the head (for a bolt), and what size bolt would I need to plug the oil line?
bleteaches6 Avatar
Bonney Lake, Washington, USA   USA
Curtis you may find that the price of new is the same as restoring the gauges. At least I did on my A oil/water temp a few months ago.
Jim K Avatar
Jim K James A. Krasnansky
Liberty, KY, USA   USA
1970 MG MGB GT "Chloe"
1971 MG MGB GT "Roscoe"
1972 MG MGB "Camilla"
I have a 70 & 71 GT. I don't think you need to pull the sensors to or epair or replace the gauges themselves. The "sensors" are electrical and they may need replaced themselves. The water temp thermocouple is pretty cheap. The switch for the oil pressure gauge is not.
They work on the 70.
Neither work on my 71 - I replaced the oil pressure gauge with a mechanical one. I replaced the voltage stabilizer a couple of times and it never did work consistently - I just got into the habit of checking the radiator frequently, and flushing the coolong system periodically - every couple of years or so.
Hope this is helpful.
sultanoswing Avatar
Jim,
The sensors on our two cars are the alcohol capillary-type, and aren't electrical in nature. I know this because when I tried to replace the sensor - hello, how does the wire from the gauge plug in to it?!
I agree with the school of thought that the water temp gauge is one of the most important to have working, since not knowing when a boil over is occurring can cost $$$.
I'll check out a cost estimate on restoration versus replacement, but either way would like to keep driving until I refit, hence the request for the bolt size to blind the hole in the head and the oil line.
Ken Plumstead Avatar
Smithers, B.C., Canada   CAN
1968 MG MGC GT
Here is the link on how to repair the temp/pressure gauge.
http://www.ply33.com/Repair/tempgauge
After you read it I'd be willing to bet $5 that you'll be ordering a new one for each car.
Ken
Jim K Avatar
Curtis - are we talking about the same thing? #10 in this pic from Moss' website is "Temp sender"
MGB-003-head.gif    49.1 KB
Jim K Avatar
#14 is oil pressure switch
MGB-092-minor electrical.gif    27.2 KB
willyumz Avatar
willyumz Lawrie Williams
Sydney, Australia   AUS
Curtis, I have the dual temp/oil pressure gauge (both mechanical) with the temp gauge capilary tube and ether filled bulb and the oil pressure direct oil line. I just had mine refurbished (both sides) for a little under A$275. I wasn't prepared to drive without water temp and oil pressure gauges. Luckily the shop had a donor one sent away and then just replaced mine with the refurb one.
Lawrie
Jim K Avatar
Curtis & Lawrie - I think you are showing me something I didn't know. Get some pics if you proceed with the temp gauge.
I know enough to know I don't know enough. smiling smiley
RAY 67 TOURER Avatar
RAY 67 TOURER Ray Marloff
Fort Bragg, CA, USA   USA
1967 MG MGB "My Girl"
European and Australian Bs used the '62 to '67 mechanical combination "Safety Gauge" right up until the end of production. They never had the electric gauges that were fitted to North American cars. RAY
Jim K Avatar
Thanks, Ray - now I know something else!
sultanoswing Avatar
In reply to a post by RAY 67 TOURER European and Australian Bs used the '62 to '67 mechanical combination "Safety Gauge" right up until the end of production. They never had the electric gauges that were fitted to North American cars. RAY
So did New Zealand B's (have the mechanical gauges, that is).
willyumz Avatar
James, Not sure what picture you want. The gauge is a round one with oil pressure on the top half and temp on the bottom. The picture attached shows the connections in the engine bay. For the temp there is a capiliary tube with a coil around it just under the thermostat housing right side of picture. The tube is clearer on the left side of the picture on the bulk head. Behind the brass fitting there is a bulb probably about 3/4 inch long filled with ether. The oil pressure connection is shown on the left of the picture. It is the braided flexible hose with the yellow band just to the left of the #4 plug lead. On the bulkhead it changes to a thin copper tube which goes directly to the gauge.
Curtis, I am not a historian so I don't know where your car was assembled and therefore what type of gauges it might have. If the VIN starts with a "Y" ie YGHNxxxxxx, I think it was assembled in Australia! Lawrie
DCP_1588.JPG    36.3 KB
melbaver Avatar
1968 MG MGB "Moneypit"
There's a new (still in box) combo one for sale on the Sydney MGCC site. They want $150 for it.
Chris Howells
mrbarry Avatar
mrbarry michael barry
dover tn, USA   USA
1979 MG MGB "Moanin' Joan"
1991 Ford Bronco
150 american is what moss wants + shipping
smiths.jpg    36 KB
1970 MG MGB GT
