firing order
fxdwglide jim white
kodak tn, USA   USA
1976? runs good low power firing order is 1432 not 1342 if I change it to 1342 it only hit on 2 cyclinders also pulling number 3 does not change engine idle ?
chris Avatar
Pendleton, OR, USA   USA
Pulling a plug wire and no change in idle speed indicates a dead hole; either no spark or no compression.
Firing order is 1342 counter clockwise.
Edit: Where are you looking on the distributor for #1? Above or below the clamp?
Edited 1 time(s). Last edit at 2010-05-29 10:22 AM by chris.
Not just for MG parts. Check out the Vendor Market page for ever changing specials.
fxdwglide jim white
kodak tn, USA   USA
it will only run with it in 1432 order it has spark and comp I am not sure of the engine year the car is a 1976 but I bought a new dis cap and it was wrong the engine number is 18V801AEL3170 if anyone knows that my help this is my first mg
chris Avatar
Which distributor cap position are you using as #1?
Edited 1 time(s). Last edit at 2010-05-29 10:27 AM by chris.
fxdwglide jim white
kodak tn, USA   USA
top right
rrmgb Avatar
Reston, VA., USA   USA
So far so good thumbs up
Is # 1 piston (front of engine) on compression stroke?
Next one to fire is #3. Top left on dist.cap. About 10 or 11 o'clock.
Then #4 at 7 o'clock, then #2 at 4 o'clock on the cap.
Verify #1 piston is on compression stroke!
Welcome to the MGE Jim! We'll have you up and runnin in no time!
RS
Sir Winston Churchill
G.S.George PHD
PaulP Avatar
PaulP Gold Member Paul Peterson
Seattle, WA, USA   USA
1973 MG MGB GT
Can you take a picture of the right side of the engine?
Fairfield, CA, USA   USA
#1 is at the front of the engine, not the rear.
Something is basically wrong or else there's some misunderstanding involved. the car won't run well (or at all) with the order you say it needs to have)
the firing order 1-3-4-2 is common to every inline 4 cylinder engine I have ever seen. Including ones in brand new cars, so it is not an MG oddity.
SUs, Datsun 5-speed
Rod H. Avatar
Amity, Oregon, USA   USA
1964 MG MGB
1968 MG MGB GT
Start from square one. Pull the valve cover and rotate the engine until the valves on #4 are on overlap, which places #1 at TDC firing. Observe if the rotor is pointing at the wire going to #1 cylinder. Make sure the wire just one position counterclockwiseis running to #3, then the next one counterclockwise is running to #4, and the last one is running to #2. Like Mac said, the cylinders are numbered with #1 at the front of the engine.
Also, they are numbered #1, #2, #3, #4, front to back.
I'm not trying to be a smart alec...A while back someone on the forum thought that since the firing order is 1342, the cylinders are numbered that way front to back!
'63 MGB
'68 MGBGT
'80 VW Vanagon Kombi
In reply to a post by Rod H. I'm not trying to be a smart alec...A while back someone on the forum thought that since the firing order is 1342, the cylinders are numbered that way front to back!
exactly! We've even had an episode of someone trying to run SUs with no needle in the piston (and a related episode of the rebuilder not putting the needle in there before shipping!<G>winking smiley
And at least one maker does number then back to front...SAAB, except that there the front of the engine in (was) in back so it really was front to back, but turned around)
SUs, Datsun 5-speed
Rod H. Avatar
1964 MG MGB
1968 MG MGB GT
In reply to a post by mac townsend
Any car that you can change the clutch withough separating the engine and transmission hasto be a little odd!
Then there are air cooled bugs that put #1 toward the front of the car, even though that's the rear of the engine...or is it the front? winking smiley
Manuals are good!
'63 MGB
'68 MGBGT
gotcha there, Rod. <G> I think I said "inline 4"...<LOL>
Subie and other pancake engines, like the bug, V4's like some Lancias and German Fords, and probably some engines I've not seen probably won't adhere to 1-3-4-2.
You are sooo right about "manuals are good"
Manuals are good!
SUs, Datsun 5-speed
Rod H. Avatar
1964 MG MGB
1968 MG MGB GT
Actually, Mac, believe it or not mid 60s Toyota Coronas had an inline four with an oddball firing order of 1243. I remember this because I worked on a few and it caused some trouble! confused smiley
By the late 60s they saw the error in their ways, and went with the accepted norm...
'63 MGB
'68 MGBGT
golf bernard lanigan
montgomery al, USA   USA
1976 MG MGB "The B"
1976 MG MGB "The B"
The Puegeot and jag ,,number 1 is next to fly wheel and thats the power take-off point
so that is Correct ! Flat head fords had number 1 thru 4 on one bank and 5thru 8 on
the other..
All crank journals travel a true circle. So you can time it by any cylinder thats on
TDC compression stroke
