5speed conversion
nicene william sanders
smithfield, nc, USA   USA
first post. howdy ya'll. i've been exhaustively searching thru all the old posts and archived threads about the many 5speed conversions. i've settled on a t5 with the ratios that i've been looking for. now here's the question....
anybody have any experience with the bell housings that are being sold on ebay?
http://cgi.ebay.com/ebaymotors/MGB-Bell-Housing-5-Speed-Transmission_W0QQitemZ360156412044QQcmdZViewItemQQptZMotors_Car_Truck_Parts_Accessories?hash=item53dafeb88c
they're for a t9, but i'm wondering if they could be made to fit a t5 with a little work.
i've been trying to get some dimensions from the seller, but they havn't responded yet. i'm concerned about the depth of the housing and the diameter of the input shaft hole. i'm guessing that i'll have to re-drill some mounting holes for the t5 bolts or get an adapter fabbed up at a machine shop?
this looks like an ideal purchase rather than having to hack up an existing mgb tranny and deal with all the machining issues.
any thoughts, advice?
mowogman Avatar
mowogman Bryan Frazier
NC, USA   USA
Welcome aboard!
Sorry I cant help out with T5 information. We have a large group of Enthusiast local to your area. You may be interested in checking us out. http://autos.groups.yahoo.com/group/ccbas66/
That ebay seller is Pierce Manifold, which is a reputable vendor. It looks to be same as with the T9 unit I have here with my new T9 kit, minus the throw oput bearing pivot plate. Now I know it will not bolt onto a T5 in any thing resembling what it is now, now with that being said, I'm sure with enough modifcation it could be made to wrok. Bob White who post here is using the T5 trannys in a MGB, he is custom making his own bellhousing using the front section of a MGB gear case, I think I would talk to Bob about getting you one made, thet may be the easier route if you set on the T5, I know Bob has looked at my T9 bellhousing, so he's familar with them.
The T9 kit is a nice set up, it uses all the normal MGB clutch and flywheel pieces right down to the stock clutch disc, so thats nice as you never have to worry about any special parts, it all common MGB stuff, it higher than the Datsun set up, but comes with a newly rebuilt tranny, but it's a very straight forward approach with very minimal changes to the original MGB clutch and flywheel piece and even looks like a MGB tranny in the car when viewing thru the engine bay, thats important to some customer.
thanks for the info hap. yeah, i've been reading a lot of what bob and joemama have done. i've already settled on the t5 as is just makes better sense. i can reuse nearly all the stock clutch stuff except for the disc providing i get the bell housing situation straightened out. i had actually found a t9 out of a merkur for cheap, but as i found out, parts are just damn near impossible to find for those transmissions. i called around to a number of distributors and tranmission shops.
i just picked up a t5 recently that came out of a 97 mustang. i was originally gonna go the route that bob is going, but i'm thinking that the ebay part may be the cheaper/easier way to go in the long run. you wouldn't happen to have any of the dimensions from your t9 bellhousing, would you? i'll send bob a pm to see if he's got any advice with the ebay listing.
thanks.
oh and btw hap, i was probably gonna be getting in touch with you in the near future about some head/valve work and discuss some options related to that.
Jim Lema Avatar
Sunny Seattle, USA   USA
1967 MG MGB
I don't know the length of the input shaft on the two transmissions. If the T9 shaft is longer from the end to the face of the transmission case you would not be able to use the bell housing. As for T9 parts, they should be available in the UK. I would check with Bob White and see why he didn't try to use the T9 bellhousing. Would be nice if someone made a bellhousing that would work with the T5.
Jim Lema Avatar
1967 MG MGB
On Quantumechanic.com site it says that the input shaft of the T9 is 160mm. That's 6.299 inches.
SafetyFast Avatar
SafetyFast Gold Member Shareef Hassan
Murrieta, California, USA   USA
Also try BAT for Type-9 parts.
In reply to a post by Jim Lema On Quantumechanic.com site it says that the input shaft of the T9 is 160mm. That's 6.299 inches.
yeah, i've already figured that i'm gonna have to have the input shaft machined since i've got the t5 with the longer input shaft. it came out of a 97 mustang and has the .73 5th gear. i just sent joemama a pm. i'll see what he has to say about the t9 housing.
here's another question while i'm at it...
how do you measure the length of the input shaft. for my model t5, the input shaft should be 7.85, but none of my measurements show that number. measuring from the top of the roller bearing race, i get about 7.67in.
so how do i measure the length of a t5 input shaft. and for that matter, how is the length of a t9 input shaft being measured?
chris Avatar
Pendleton, OR, USA   USA
Does the T5 fit the MGB pilot bushing? I just installed a T9 kit into an MGA running a 3-main MGB engine, and part of the kit was a carrier/extension for the pilot bushing that you had to drive into the flywheel.
i doubt very seriously that it fits into the bushing. i already knew before buying the tranny that i was gonna get the input shaft machined. i was just gonna machine the t5 pilot to the mgb stock diameter. either that or get a new bushing machined.
chris Avatar
So, you have the correct length with the T5 then? With the T9, part of the pilot bushing housing's function was to work as an extension.
i'm not sure. i guess i won't know until i get the bell housing and do some measuring.
so how long is the spigot bush adapter for the t9 kit? and how much does the t9 pilot engage the bushing?
chris Avatar
It extends about 1/2" to the rear of the flywheel and must be about 3/4" inside the flywheel.
In the case of the T9, the input shaft diamater is smaller than the stock MGB, so a pilot bushing is made from bronze with a smaller ID for the smaller input shaft and the same od as the stock busihing , it would be easy enough to make, a simple lathe job, even a widdler like me smiling smiley could pull it off. I have no idea if the input shaft on the T5 is too large to work with the back of the MGB crankshaft, I'm thinking not, knowing Bob has already done this conversion in our talks of this I don't recall him saying the input shaft was machined.
Will before you chunk out over 200 bucks for a bellhousing that may or may not work with a T5, I would talk to Bob, and you can call me on any measurements on the T9/MGB bellhousing, which I have a brand new one sittting in my shop. What I'm thinking is might end up being fairly indept machining fabrication job to convert the T9/MGB bellhousing for the T5, and what Bob is doing now is more cost effective. I've built a dyno adapter using the front section of a Midget gearbox, and it was fairly complicated and expensive, so maybe starting off with a MGB gearbox case for say 50 bucks would be better than starting off with the T9/MGB bellhousing for 200+. Bottom line if you end up having to cut the back off the T9 bellhousing to get the length you need, it would be the same thing as using a MGB gearbox case anyway.
