High compression engine.
BRAVO-4 Avatar
BRAVO-4 CRAIG PURYEAR
norfolk, virginia, USA   USA
1971 MG MGB "The Killer Tomato"
1979 MG MGB "MAURICE"
So i find out my 71B has a high compression engine, What does that mean for me, good bad, special? anything special I need to be aware of?, thanks, I feel stupid know.
My engine number is
18GK-WE-H-631
Ralph 7h Avatar
Ralph 7h Ralph Siebenhaar
Viersen, Germany   DEU
Nothing to worry about.
I would ask Jeff Schlemer to built me an adequate dizzy for using all the performance this engine can provide.
Fairfield, CA, USA   USA
In reply to a post by Ralph 7h Nothing to worry about.
but be aware that your socks will remain unbothered by said increased performance<G> (i.e. it will not "knock your socks off"winking smiley
SUs, Datsun 5-speed
underdog Avatar
underdog Jim Underwood
Pittsburgh, USA   USA
1980 Triumph TR8 "Fabulous Trashwagon"
1999 Chevrolet Corvette "Darth Vader"
1999 Chevrolet S10 "Spare Change"    & more
Even the HC engines were only 8.8 to 1. Not exactly high compression by American car standards. I have a 70 Cadillac that came with 10.5 to 1 as did the Muscle Cars before the EPA came along with unleaded fuel in 71-72.
Ralph 7h Avatar
Mac,
you are certainly right, but it might pretend the engine from melting piston tops down to the first compression ring on highway speeds. Just a personal experience...
Ralph
scotabbott Avatar
scotabbott Scot Abbott
Pittsburgh, Pa 15216, USA   USA
1974 MG MGB "Bee"
In their prime, the B motors only produced about 85 HP, which by the standards of the day was on the low side of "OK". Most cars of those days were producing a more than 1 HP per cubic inch, and the best years of the B fell short of that. Later years of B with lowered compression ratio, poorer carbs and retarded timing reduced the output to about 50 HP, which is pretty poor by most any standard.
A motorcycle made at the time of the B's (e.g. honda cb 500) of 500 cc dislacement produces 50+ HP. Scaling for displacement, that corresponds to about 180 HP for a 1.8 liter motor. (i.e. 1HP per 10 CC). Many car motors do about as well these days.
Any way you slice it, the B motor does a pretty poor job. In al.l the stock forms, there is little power but lots of air pollution and fairly poor gas mileage. The kinds of improvements for the B (in order of increasing cost, and decreasing bang for the buck) are :
recurve the dizzy and add electroic ignition
replace single carb with twin carb setup
add high compression pistons
replace carbs with fuel injection
add a better cam
head work or replace head
I personally favor the route of a recurved dizzy, hi compression pistons and fuel injection. (never tried the cam)Makes the B run really nice, reliable and clean. It is not as drastic or expesive as an engine swap or adding a supercharger.
Edited 1 time(s). Last edit at 2010-03-09 05:44 PM by scotabbott.
MrMarty51 Avatar
MrMarty51 Martin Draper
Miles City,Montana, USA   USA
1978 MG MGB "Little Red Crapper Car"
In reply to a post by scotabbott In their prime, the B motors only produced about 85 HP, which by the standards of the day was on the low side of "OK". Most cars of those days were producing a more than 1 HP per cubic inch, and the best years of the B fell short of that. Later years of B with lowered compression ratio, poorer carbs and retarded timing reduced the output to about 50 HP, which is pretty poor by most any standard.
add a better cam
:thumbsup:
1967 MG MGB MkI
