What's the hard part on a brake master cylinder install?
Caruthers Avatar
Caruthers Jim Cardamone
Baltimore MD, USA   USA
I've been reading past posts about swapping out a new master cylinder in my 79 and have read what a pain it is to get in. I'm probably going to go ahead and get a rebuilt one insead of rebuilding it myself - http://cgi.ebay.com/ebaymotors/MGB-MG-Brake-Master-Cylinder-75-76-77-78-79-80-81_W0QQcmdZViewItemQQ_trkparmsZ65Q3a12Q7c66Q3a2Q7c39Q3a1Q7c72Q3a2103Q7c240Q3a1318Q7c301Q3a1Q7c293Q3a1Q7c294Q3a50QQ_trksidZp3286Q2ec0Q2em14QQhashZitem518718fa9eQQitemZ350158912158QQptZMotorsQ5fCarQ5fTruckQ5fPartsQ5fAccessories
So it looks pretty simple, a few brake lines, a couple of bolts and a pin or two. The pita that can be bleeding the brakes not withstanding, what's the hard part?
rakmgb Avatar
rakmgb Roger Killin
Nanaimo, BC, Canada   CAN
1970 MG MGB "Sarah"
Every thing after you take it out of the box.
GSU130 Avatar
GSU130 Richard Roberts
Gloucestershire, UK   GBR
1929 Ford HOT ROD A
1979 MG MGB GT "RUBY"
Hard part paying for it £142 UK price your e-bay price is very reasonable.
Mine requires replacement noticed the pedal creeping downwards on very steep hills on a 100mls MG run @ the weekend seals must be worn.
Regards Richard.
kpslater Kris Slater
Gilbert, AZ, USA   USA
In my experience, bleeding the master cylinder itself is the hardest part (while still not that difficult). Bench bleed it first before you put it in and it will make your job easier. If you are comfortable bleeding brakes then it shouldn't be too difficult.
http://www.phxheli.com/ks/ksmain.html
Davenport, Iowa, USA   USA
Jim,
I have no axe to grind one way or another but the item on ebay isn't remotely like the OEM item. Look closely Tank is not tilted, forward outlet has TWO outlets, one quite visable the other down under but the cap is showing.
While this may in fact work I strongly suggest it may not if for no other reason than the 3 outlets in an MGB two outlet system.
For another $21 you can get a bonafide replacement BMC KNOWN to fit your car.
Regards,
Robert Kirk
kirkbrit@yahoo.com
Business phone 563 323 1017
Orders only please 800 547 5747
cell, if I have it, 563 940 1864
http://kirks-auto.com/
Moss distributor/UK importer
Caruthers Avatar
Robert, that's kinda funny since I looked at my old one and it had all the same stuff as the ebay one, outlets and tank. So it looks like my previous owner used a non OEM part too. Since it's gone at least 8 years (I bought the car in 01) I figure it can't be that bad. Where can I find the one you are talking about for a few bucks more?
PM sent.
Does yours have the twin output on the forward (closest to firewall) position? THAT'S what threw me!
Regards,
Robert Kirk
kirkbrit@yahoo.com
The Wiz Avatar
The Wiz Mike The Wiz Barnes
STL, MO, USA   USA
1969 MG MGB GT
1971 MG MGB GT "Blueberry"
1979 MG MGB "PopTop"
2000 Ford Ranger SC4x4    & more
My 79 has three outlets, the tank on the replacement I bought from Moss is not tilted.
Nulla tenaci invia est via
1971 MGBGT, overdrive, Limey relay and fuse kits, Rick Ingram struts all round, Jeff Schlemmer points distributor, mgccars.com alternator, Basil Adams camshaft and side cover, Eurospec tail lights, 1976 dashboard and console, 1999 Chevy cavalier seats, GM heater motor and fan with Ford 3 speed controller, Ford Merkur/Sierra parcel shelf, cruise control.
1979 B, Olds 215 engine with 1996 Landrover heads, Carter AFB, Camaro T5 gearbox, Limey relay kit, Rick Ingram struts all round, mgccars alternator, Jeff Schlemmer distributor with Petronix, Eurospec tail lights, cruise control, 99 Pontiac Sunfire seats.
1969 MGBGT, Miata seats, late centre console, apart from that it's stock!
Be Coming Avatar
Be Coming Kelvin Dodd
So. Calif., USA   USA
Jim. It's a pretty easy job on the late MGB. If you can get ahold of either a pressure or vacuum bleeding rig, it does make the process a lot faster and easier.
There is nothing inherently weird about the process, so get in there and "git her done"!
rrmgb Avatar
Reston, VA., USA   USA
There is nothing difficult about it on a '79. Everything is out in the open and pedal box cover comes off easily.
Now, if you have rusted cotter pins to remove, or push rod yokes to repair, thats a different story.
RS
Sir Winston Churchill
G.S.George PHD
underdog Avatar
underdog Jim Underwood
Pittsburgh, USA   USA
1980 Triumph TR8 "Fabulous Trashwagon"
1999 Chevrolet Corvette "Darth Vader"
1999 Chevrolet S10 "Spare Change"    & more
Not spilling fluid on the paint. That is unless it's already been done.smiling smiley
kstevusa Avatar
kstevusa kelly stevenson
Huntsville, Lwr. Middle Tennessee, USA   USA
1978 MG MGB V8 Conversion "Must-B"
2003 Jaguar XK8 "Nigel"
Just installed a new TRW brand on my 78 B last week from a member (Basil Adams). the whole new one was less than $180 incl S&H. Basil is a 1st class person. The M/C was top notch and easy to install. You can contact him with a PM and get info.
Gerald O Avatar
Gerald O Gerald O'Docharty
1978 MG MGB
That MC depicted in the ebay auction appears to match the one in my '78, which is still the original.
Gerald O Wrote:
Quote: That MC depicted in the ebay auction appears to match the one in my '78, which is still the original.
I would just like to know why the front break port has two outlets. Anyone? That is the only thing that "looks" wrong to me. The OEM clearly is illustrated as having a single port for the front and the rear
It wouldn't be the first time I didn't "see" clearly!
;^D
Regards,
Robert Kirk
kirkbrit@yahoo.com
Gerald O Avatar
1978 MG MGB
kirks-auto Wrote:
Quote: I would just like to know why the front break port has two outlets. Anyone? That is the only thing that "looks" wrong to me. The OEM clearly is illustrated as having a single port for the front and the rear
;^D
There is a separate brake pipe for each side of the car for the fronts.
