Leaking side covers
moreso74 Avatar
moreso74 David Maples
Augusta, Georgia, USA   USA
Previous thread
<http://mgbexperience.com/phorum/read.php?f=1&i=111099&t=110941#reply_111099>;
In addition to the stuff before, I bounced the rubble of the oil leak by rounding off the inside corner of the gasket. My purpose was to match the curve of the metal case. The gasket is square in cross-section but the area that it sits in is not. By using a Dremel with a sanding drum, I shaped the gasket to match the curve of the metal, taking special care with the corner areas.
When finished, the gasket sits flat on the side cover and doesn't try to creep up and out. When using adhesive, put a little up the vertical side as well as the flat portion. Don't go too far up the vertical side because you don't want to expose the adhesive to the engine atmosphere.
In the picture below: At the top of the side cover is a gasket cut open to show the curved inner side. The other cover is flipped to show the safety wire tab. It doesn't show up well in the black paint.
Post Edited (10-09-03 10:52)
David
Rod H. Avatar
Amity, Oregon, USA   USA
1964 MG MGB
1968 MG MGB GT
Is the cork type gasket no longer available for the front side cover?
Rod H.
moreso74 Avatar
As far as I know, the cork gaskets are still being sold. I just have a thing against the cork.
David
Rod H. Avatar
1964 MG MGB
1968 MG MGB GT
nt
chris Avatar
Pendleton, OR, USA   USA
You're in Portland?
Not just for MG parts. Check out the Vendor Market page for ever changing specials.
jgbowman Avatar
jgbowman Greg B
Greeneville Tn, USA   USA
This may be a stupid question, but I've never had my side covers off. Is the square hole on the back of the cover where the mesh goes? Is that hole there or did you cut it in?
Greg
'73 B Mallard Green
18GH with Brittek 270 cam, Balanced
SU HS6
Peco header and exhaust
Eurospec dizzy, Lucas Sport Coil
O/D Black label
Kumho Solus 195/60-14 on Miniators
http://safetyfast.multiply.com/photos/album/4
Rod H. Avatar
1964 MG MGB
1968 MG MGB GT
But lived in Portland for 41 years.
You're in Portand?
Rod H.
Rod H. Avatar
1964 MG MGB
1968 MG MGB GT
nt
moreso74 Avatar
That hole is the way it is built. You can just see the wire mesh oil separator up inside there.
David
